Введение
Use this guide to replace a cracked or broken screen in your Samsung Galaxy A50.
Note: The function of the fingerprint sensor might be lost after this screen replacement. Security patches installed after September 2020 don’t support this repair.
This guide instructs you to replace only the screen while leaving the original frame and motherboard in place. However, some replacement screens for this phone come pre-installed in a new frame (a.k.a. chassis), which requires a very different procedure. Make sure you have the correct part before starting this guide.
Before disassembling your phone, discharge the battery below 25%. The battery can catch fire and/or explode if accidentally punctured, but the chances of that happening are much lower if discharged.
You’ll need replacement adhesive to reattach components when reassembling the device.
Выберете то, что вам нужно
Insert a SIM card eject tool, a SIM eject bit or a straightened paper clip into the hole on the SIM tray located at the left side of the phone.
Press firmly to eject the tray.
Remove the SIM card tray.
Start by switching off your phone.
Heat an iOpener and apply it to the back cover to soften the adhesive.
Insert an opening pick at the bottom of your phone near the USB-C port.
Slide the opening pick to the bottom left corner.
Insert a second opening pick and slide it from the bottom to the top left corner to cut the adhesive.
Leave the opening picks in place to prevent the adhesive from resealing.
Insert a third opening pick under the top left corner of the back cover.
Slide the opening pick along the top edge of the phone.
Leave the opening pick in the top right corner to prevent the adhesive from resealing.
Insert a fourth opening pick under the top right corner of the back cover.
Slide the tip of the opening pick along the side of the phone to the bottom right corner to cut the adhesive.
Leave the opening pick in the bottom right corner to prevent the adhesive from resealing.
Insert an opening pick between the display and the midframe at the bottom of your phone above the USB-C port.
Slide the pick along the bottom edge to release the clips.
Continue sliding the pick along the left edge of the phone to release the clips.
Use a spudger to disconnect the battery by prying the connector straight up from its socket.
Use a spudger to disconnect the front camera by prying the connector straight up from its socket.
Use the flat end of a spudger to pry up and disconnect the interconnect and display flex cable from the daughterboard.
Carefully bend both cables out of the way.
Use the tip of a spudger to loosen the display connector above the daughterboard.
Heat an iOpener and apply it on the display for at least two minutes to soften the adhesive underneath.
Place a suction handle close to the right edge of the display and pull with firm steady force for 30 seconds to loosen the adhesive.
Re-apply a heated iOpener to the display for about one minute.
Pull the suction cup upwards and insert an opening pick into the gap between the display and the frame.
Slide the opening pick down to the bottom right corner.
Leave it there to prevent the adhesive from resealing.
Insert a second opening pick and slide it to the top right corner of the phone to cut the adhesive.
Leave the pick in its place to prevent the adhesive from resealing.
Insert a third opening pick and slide it to the top left corner.
Leave the picks in their place to prevent the adhesive from resealing.
Insert a fourth opening pick at the top left corner.
Slide the opening pick up to the bottom left corner to cut the adhesive. Leave it there to prevent the adhesive from resealing.
Insert a fifth opening pick and slide it along the bottom edge of the phone to cut the remaining adhesive.
Apply a heated iOpener to the display to loosen the adhesive underneath the screen.
As you wait, take note of the rectangular-shaped adhesive placed on the back of the screen.
Insert a plastic card into the loosened left edge of the phone.
Press the plastic card in and slide it back and forth until you cut through the entire adhesive.
Once you are sure you cut through the adhesive, remove the four opening picks from the corners.
Lift the screen from the top edge of the phone.
Carefully thread the display cable through the frame.
Remove the screen.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
The best way to secure the new screen is to apply a sheet of custom-cut double-sided tape to the back of the screen.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
62 участников успешно повторили данное руководство.
24 Комментариев
considering it is embedded within the display assembly, any chance that the fingerprint sensor is affected by replacing the screen?
Hi Steve, the fingerprint sensor is not embedded within the display as you can see here. The sensor is fixed under the frame and can be seen through the hole in the frame.
Hey, I followed this procedure to replace my screen and now, whenever I am charging my phone it keeps on rebooting itself every 3-5 seconds, or even when it’s not charging and is just idle. I tried to open it up and realign everything however it didn’t help and kept rebooting. So I am not quite sure what I did wrong and was wondering if you have ever experienced that, and what to do about it.
sounds like you may have damaged the battery in some way, try replacing the battery!
