Samsung Galaxy A53 5G Loudspeaker Replacement
Выберете то, что вам нужно
  1. Samsung Galaxy A53 5G Loudspeaker Replacement, Heat the back cover: шаг 1, изображение 1 из 1
    • Prepare an iOpener and apply it to the back cover for at least two minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Samsung Galaxy A53 5G Loudspeaker Replacement, Insert an opening pick: шаг 2, изображение 1 из 2 Samsung Galaxy A53 5G Loudspeaker Replacement, Insert an opening pick: шаг 2, изображение 2 из 2
    • Secure a suction handle to the right edge of the back cover, as close to the edge as possible.
    • Lift the back cover with the suction handle to create a small gap between the back cover and the frame.
    • In case you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap you created.
  3. Samsung Galaxy A53 5G Loudspeaker Replacement, Slice the adhesive: шаг 3, изображение 1 из 3 Samsung Galaxy A53 5G Loudspeaker Replacement, Slice the adhesive: шаг 3, изображение 2 из 3 Samsung Galaxy A53 5G Loudspeaker Replacement, Slice the adhesive: шаг 3, изображение 3 из 3
    • Slide the opening pick to the top right corner to slice the adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  4. Samsung Galaxy A53 5G Loudspeaker Replacement, Slice the adhesive: шаг 4, изображение 1 из 3 Samsung Galaxy A53 5G Loudspeaker Replacement, Slice the adhesive: шаг 4, изображение 2 из 3 Samsung Galaxy A53 5G Loudspeaker Replacement, Slice the adhesive: шаг 4, изображение 3 из 3
    • Insert a second opening pick at the top right edge of your phone.
    • Slide the opening pick to the bottom right corner to slice the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  5. Samsung Galaxy A53 5G Loudspeaker Replacement: шаг 5, изображение 1 из 3 Samsung Galaxy A53 5G Loudspeaker Replacement: шаг 5, изображение 2 из 3 Samsung Galaxy A53 5G Loudspeaker Replacement: шаг 5, изображение 3 из 3
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener for one to two minutes to reheat it.
    • Insert a third opening pick at the bottom right corner of your phone.
    • Slide the opening pick along the bottom edge of your phone to slice the adhesive.
    • Leave the opening pick in the bottom left corner to prevent the adhesive from resealing.
  6. Samsung Galaxy A53 5G Loudspeaker Replacement: шаг 6, изображение 1 из 3 Samsung Galaxy A53 5G Loudspeaker Replacement: шаг 6, изображение 2 из 3 Samsung Galaxy A53 5G Loudspeaker Replacement: шаг 6, изображение 3 из 3
    • Insert a fourth opening pick at the bottom left corner of your phone.
    • Slide the opening pick along the left edge to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  7. Samsung Galaxy A53 5G Loudspeaker Replacement: шаг 7, изображение 1 из 2 Samsung Galaxy A53 5G Loudspeaker Replacement: шаг 7, изображение 2 из 2
    • Insert a fifth opening pick at the top left corner.
    • Slide the opening pick along the top edge of the back cover to slice the remaining adhesive.
  8. Samsung Galaxy A53 5G Loudspeaker Replacement, Remove the back cover: шаг 8, изображение 1 из 1
    • Remove the back cover.
    • Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • Secure the new back cover with pre-cut adhesive or double-sided adhesive tape. After installing the back cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
  9. Samsung Galaxy A53 5G Loudspeaker Replacement, Unscrew the motherboard cover: шаг 9, изображение 1 из 1
    • Use a Phillips screwdriver to remove the eight 3.9 mm-long screws securing the motherboard cover.
  10. Samsung Galaxy A53 5G Loudspeaker Replacement, Pry up the motherboard cover: шаг 10, изображение 1 из 3 Samsung Galaxy A53 5G Loudspeaker Replacement, Pry up the motherboard cover: шаг 10, изображение 2 из 3 Samsung Galaxy A53 5G Loudspeaker Replacement, Pry up the motherboard cover: шаг 10, изображение 3 из 3
    • Insert the flat end of an spudger into the gap between the frame and the motherboard cover on the right edge.
    • Use the spudger to pry up the motherboard cover.
  11. Samsung Galaxy A53 5G Loudspeaker Replacement, Remove the motherboard cover: шаг 11, изображение 1 из 1
    • Remove the motherboard cover.
  12. Samsung Galaxy A53 5G Loudspeaker Replacement, Disconnect the battery cable: шаг 12, изображение 1 из 2 Samsung Galaxy A53 5G Loudspeaker Replacement, Disconnect the battery cable: шаг 12, изображение 2 из 2
    • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
  13. Samsung Galaxy A53 5G Loudspeaker Replacement, Unfasten the loudspeaker screws: шаг 13, изображение 1 из 1
    • Use a Phillips screwdriver to remove the seven 3.9 mm-long screws securing the loudspeaker assembly.
  14. Samsung Galaxy A53 5G Loudspeaker Replacement, Remove the loudspeaker: шаг 14, изображение 1 из 3 Samsung Galaxy A53 5G Loudspeaker Replacement, Remove the loudspeaker: шаг 14, изображение 2 из 3 Samsung Galaxy A53 5G Loudspeaker Replacement, Remove the loudspeaker: шаг 14, изображение 3 из 3
    • Insert the flat end of a spudger into the gap between the right edge of the loudspeaker assembly and the midframe.
    • Use your spudger to pry up the loudspeaker assembly.
    • Remove the loudspeaker assembly.
Заключение
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
Еще один человек закончил это руководство.
Adriana Zwink
Участник с: 12/18/19
48 052 Репутация
Автор 167 руководств
Команда
iFixit Участник iFixit
Staff
135 членов
Автор 16 718 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 28
За последние 30 дней: 97
За всё время: 1,839
