Samsung Galaxy A72 Screen Replacement
Выберете то, что вам нужно
  1. Samsung Galaxy A72 Screen Replacement, Heat the back cover: шаг 1, изображение 1 из 1
    • Prepare an iOpener and apply it to the back cover for at least two minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Samsung Galaxy A72 Screen Replacement, Insert an opening pick: шаг 2, изображение 1 из 3 Samsung Galaxy A72 Screen Replacement, Insert an opening pick: шаг 2, изображение 2 из 3 Samsung Galaxy A72 Screen Replacement, Insert an opening pick: шаг 2, изображение 3 из 3
    • Secure a suction handle to the bottom edge of the back cover, as close to the edge as possible.
    • If the back cover is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Lift the back cover with the suction handle to create a small gap between the back cover and the frame.
    • In case you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap you created.
    • Slide the opening pick to the bottom right corner to slice the adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  3. Samsung Galaxy A72 Screen Replacement, Slice the adhesive: шаг 3, изображение 1 из 2 Samsung Galaxy A72 Screen Replacement, Slice the adhesive: шаг 3, изображение 2 из 2
    • Insert a second opening pick at the bottom edge of your phone.
    • Slide the opening pick to the bottom left corner to slice the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  4. Samsung Galaxy A72 Screen Replacement, Slice the adhesive: шаг 4, изображение 1 из 3 Samsung Galaxy A72 Screen Replacement, Slice the adhesive: шаг 4, изображение 2 из 3 Samsung Galaxy A72 Screen Replacement, Slice the adhesive: шаг 4, изображение 3 из 3
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener for one to two minutes to reheat it.
    • Insert a third opening pick at the bottom left corner of your phone.
    • Slide the opening pick along the left edge of your phone to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  5. Samsung Galaxy A72 Screen Replacement: шаг 5, изображение 1 из 2 Samsung Galaxy A72 Screen Replacement: шаг 5, изображение 2 из 2
    • Insert a fourth opening pick underneath the top left corner of your phone.
    • Slide the opening pick along the top edge to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  6. Samsung Galaxy A72 Screen Replacement: шаг 6, изображение 1 из 2 Samsung Galaxy A72 Screen Replacement: шаг 6, изображение 2 из 2
    • Insert a fifth opening pick underneath the top right corner.
    • Slide the opening pick along the right edge of the back cover to slice the remaining adhesive.
  7. Samsung Galaxy A72 Screen Replacement, Remove the back cover: шаг 7, изображение 1 из 2 Samsung Galaxy A72 Screen Replacement, Remove the back cover: шаг 7, изображение 2 из 2
    • Remove the back cover.
    • Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • Secure the new back cover with pre-cut adhesive or double-sided adhesive tape. After installing the back cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
  8. Samsung Galaxy A72 Screen Replacement, Unfasten the motherboad cover screws: шаг 8, изображение 1 из 1
    • Use a Phillips screwdriver to remove the ten 4.5 mm-long screws securing the motherboard cover.
  9. Samsung Galaxy A72 Screen Replacement, Pry up the motherboard cover: шаг 9, изображение 1 из 2 Samsung Galaxy A72 Screen Replacement, Pry up the motherboard cover: шаг 9, изображение 2 из 2
    • Insert the pointed end of a spudger underneath the right edge of the motherboard cover.
    • Use your spudger to pry up the motherboard cover by tilting the spudger downwards.
  10. Samsung Galaxy A72 Screen Replacement, Remove the motherboard cover: шаг 10, изображение 1 из 2 Samsung Galaxy A72 Screen Replacement, Remove the motherboard cover: шаг 10, изображение 2 из 2
    • Remove the motherboard cover.
  11. Samsung Galaxy A72 Screen Replacement, Disconnect the battery cable: шаг 11, изображение 1 из 2 Samsung Galaxy A72 Screen Replacement, Disconnect the battery cable: шаг 11, изображение 2 из 2
    • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
  12. Samsung Galaxy A72 Screen Replacement, Disconnect the interconnect cable: шаг 12, изображение 1 из 2 Samsung Galaxy A72 Screen Replacement, Disconnect the interconnect cable: шаг 12, изображение 2 из 2
    • Use a spudger to disconnect the interconnect cable by prying the connector straight up from its socket.
  13. Samsung Galaxy A72 Screen Replacement, Unfasten the loudspeaker assembly screws: шаг 13, изображение 1 из 1
    • Use a Phillips screwdriver to remove the seven 4.5 mm-long screws securing the loudspeaker assembly.
  14. Samsung Galaxy A72 Screen Replacement, Pry up the loudspeaker assembly: шаг 14, изображение 1 из 2 Samsung Galaxy A72 Screen Replacement, Pry up the loudspeaker assembly: шаг 14, изображение 2 из 2
    • Insert the pointed end of a spudger underneath the right edge of the loudspeaker assembly.
    • Use your spudger to pry up the loudspeaker assembly by tilting the spudger downwards.
  15. Samsung Galaxy A72 Screen Replacement, Remove the loudspeaker assembly: шаг 15, изображение 1 из 2 Samsung Galaxy A72 Screen Replacement, Remove the loudspeaker assembly: шаг 15, изображение 2 из 2
    • Remove the loudspeaker assembly.
    • During reassembly apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
  16. Samsung Galaxy A72 Screen Replacement, Pry up the display connector: шаг 16, изображение 1 из 2 Samsung Galaxy A72 Screen Replacement, Pry up the display connector: шаг 16, изображение 2 из 2
    Инструмент, используемый на этом этапе:
    • The display connector is held in place by mild adhesive.
    • Use one arm of a pair of tweezers to carefully pry the display connector off the midframe.
  17. Samsung Galaxy A72 Screen Replacement, Loosen the display adhesive: шаг 17, изображение 1 из 1
    • Apply a heated iOpener to the screen to loosen the adhesive underneath. Apply the iOpener for at least 5 minutes.
    • The display adhesive of the Galaxy A72 is strong, and it's likely you need to reheat and reapply the iOpener several times before starting the display removal and during the removal procedure.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
  18. Samsung Galaxy A72 Screen Replacement, Create a gap: шаг 18, изображение 1 из 3 Samsung Galaxy A72 Screen Replacement, Create a gap: шаг 18, изображение 2 из 3 Samsung Galaxy A72 Screen Replacement, Create a gap: шаг 18, изображение 3 из 3
    • Once the screen is warm to touch, apply a suction cup to the left edge of the screen.
    • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the screen.
    • Lift the screen with the suction handle to create a small gap between the screen and the front panel assembly.
    • Insert an opening pick in the gap between the front panel assembly and the screen.
    • Slide the opening pick to the bottom left corner of the screen to slice its adhesive.
  19. Samsung Galaxy A72 Screen Replacement, Slice the display adhesive: шаг 19, изображение 1 из 2 Samsung Galaxy A72 Screen Replacement, Slice the display adhesive: шаг 19, изображение 2 из 2
    • Insert a second opening pick in the gap between the front panel assembly and the screen.
    • Slide the opening pick to the top left corner of the screen to slice its adhesive.
  20. Samsung Galaxy A72 Screen Replacement: шаг 20, изображение 1 из 3 Samsung Galaxy A72 Screen Replacement: шаг 20, изображение 2 из 3 Samsung Galaxy A72 Screen Replacement: шаг 20, изображение 3 из 3
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener or heat gun for 1–2 minutes to reheat it.
    • Insert a third opening pick underneath the top left corner of the screen.
    • When you slice near the front facing camera, insert only the tip of the opening pick (~2–3 mm) to avoid damaging or smearing the camera.
    • Slide the opening pick to the top right corner of the screen to slice its adhesive.
    • Leave the opening pick in its place to prevent the adhesive from resealing.
  21. Samsung Galaxy A72 Screen Replacement: шаг 21, изображение 1 из 3 Samsung Galaxy A72 Screen Replacement: шаг 21, изображение 2 из 3 Samsung Galaxy A72 Screen Replacement: шаг 21, изображение 3 из 3
    • Insert a fourth opening pick underneath the top right corner and slide it along the right edge of the phone to slice the adhesive.
  22. Samsung Galaxy A72 Screen Replacement: шаг 22, изображение 1 из 2 Samsung Galaxy A72 Screen Replacement: шаг 22, изображение 2 из 2
    • Insert a fifth opening pick at the bottom right corner of the screen.
    • Slide the opening pick along the bottom edge of the phone to slice the adhesive.
    • Do not try to remove the display all the way yet, there is still adhesive underneath the center of the screen.
  23. Samsung Galaxy A72 Screen Replacement: шаг 23, изображение 1 из 3 Samsung Galaxy A72 Screen Replacement: шаг 23, изображение 2 из 3 Samsung Galaxy A72 Screen Replacement: шаг 23, изображение 3 из 3
    Plastic Cards
    $2.99
    • Insert a plastic card underneath the top right corner of the screen.
    • Slide the plastic card along the right edge of the screen to slice the right half of the adhesive underneath.
  24. Samsung Galaxy A72 Screen Replacement: шаг 24, изображение 1 из 3 Samsung Galaxy A72 Screen Replacement: шаг 24, изображение 2 из 3 Samsung Galaxy A72 Screen Replacement: шаг 24, изображение 3 из 3
    • Insert a plastic card underneath the top left corner of the screen.
    • Slide the plastic card along the left edge of the screen to slice the left half of the adhesive underneath.
    • Do not try to remove the display all the way yet, the screen and the digitizer cable are still threaded through the front panel assembly.
  25. Samsung Galaxy A72 Screen Replacement, Free the display cable: шаг 25, изображение 1 из 2 Samsung Galaxy A72 Screen Replacement, Free the display cable: шаг 25, изображение 2 из 2
    • Thread the display cable through the gap in the front panel assembly.
  26. Samsung Galaxy A72 Screen Replacement, Remove the screen: шаг 26, изображение 1 из 2 Samsung Galaxy A72 Screen Replacement, Remove the screen: шаг 26, изображение 2 из 2
    • Remove the screen.
    • Apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • During reassembly, follow this guide in case you're using a pre-cut adhesive card.
Заключение
If possible, turn on your device and test your repair before installing new adhesive and resealing.
The best way to secure the new screen is to apply a sheet of custom-cut double-sided tape to the back of the screen.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
6 человек успешно провели ремонт по этому руководству.
Dominik Schnabelrauch
Участник с: 11/23/16
231 703 Репутация
Автор 682 руководств
Команду
iFixit Участник iFixit
Staff
121 членов
Автор 19 767 руководств
0Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 3
За последние 7 дней: 25
За последние 30 дней: 110
За всё время: 5,078
