Выберете то, что вам нужно
Видео обзор
Warm the device to soften the adhesive.
To separate the back cover, use plastic tools, a suction cup and a little ethanol alcohol.
Remove the SIM Tray.
Unscrew the silver Phillips screws and remove the motherboard plastic cover.
Disconnect the battery.
Disconnect the main flex cable.
Disconnect the Coaxial antenna cables.
Remove the black Philips screw securing the motherboard to the display frame.
Use a plastic tool to remove the Motherboard.
Remove the silver Phillips screws and with a plastic tool lift up the plastic cover.
Disconnect the fingerprint sensor.
Disconnect the Main flex cable.
Remove the black screw securing the Charging board.
Use a plastic tool and gently pick up the Daughter board.
Remove the Motor Vibrator.
Remove the Fingerprint sensor.
Before assembling the phone, test the new display using this code:
*#0*#
3 участников успешно повторили данное руководство.
