Samsung Galaxy A8(2018) Back Cover Replacement
  1. Samsung Galaxy A8(2018) Back Cover Replacement, Back cover: шаг 1, изображение 1 из 2 Samsung Galaxy A8(2018) Back Cover Replacement, Back cover: шаг 1, изображение 2 из 2
    • Turn off your phone.
    • Prepare an iOpener or hair dryer to soften the adhesive on the back of the A8.
    • The adhesive is distributed over the outline of the back cover shown in red in the photo.
  2. Samsung Galaxy A8(2018) Back Cover Replacement: шаг 2, изображение 1 из 1
    • Use a suction cup to lift the back cover and insert an opening pick into the slot created.
    • Start in the middle and cut the adhesive while maintaining tension on the suction cup.
    • If you find it increasingly difficult to move the pick, reheat the iOpener or use a hair dryer.
  3. Samsung Galaxy A8(2018) Back Cover Replacement: шаг 3, изображение 1 из 2 Samsung Galaxy A8(2018) Back Cover Replacement: шаг 3, изображение 2 из 2
    • Move your pick carefully from corner to corner. Leave a pick at each corner once it has been freed to prevent the cover from re-adhering. Repeat for all 4 corners.
    • Do not force the cover open. Re-soften the adhesive with an iOpener or hair dryer if the back cover does not come off or begins to warp.
    • On the photo opposite three corners have been released, with one corner remaining to be able to completely remove the glass.
    • Be careful not to damage the fingerprint reader connector when opening the back cover. Disconnect it following the instructions in the next step.
  4. Samsung Galaxy A8(2018) Back Cover Replacement: шаг 4, изображение 1 из 1
    • Unplug the fingerprint reader with tweezers.
  5. Samsung Galaxy A8(2018) Back Cover Replacement: шаг 5, изображение 1 из 1
    • Remove the back cover.
    • Prepare for reassembly by removing the remaining adhesive from the phone with a spudger. Clean the adhesive surfaces with isopropyl alcohol and a lint-free cloth.
Заключение
To reassemble your device, follow the instructions in reverse order.
7 человек успешно провели ремонт по этому руководству.
Особая благодарность этим переводчикам:
fr en
100%
Jerry Wheeler помогает нам починить мир! Хотите внести свой вклад?
Начните переводить ›
Jean pierre bourhis
Участник с: 03/06/18
361 Репутация
1 руководство автора
Команду
Leroy Merlin Участник Leroy Merlin
Community
38 членов
Автор 244 руководств
0Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 1
За последние 7 дней: 12
За последние 30 дней: 75
За всё время: 3,881
