Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Запчасти
Детали не указаны.
  1. Begin by turn the device over to it's back, with the screen facing down.
    • Begin by turn the device over to it's back, with the screen facing down.
  2. At the top of the device there is a small notch that is used to remove the battery door. Using a pry tool or your fingernail, pry off the battery door from the main housing.
    • At the top of the device there is a small notch that is used to remove the battery door.
    • Using a pry tool or your fingernail, pry off the battery door from the main housing.
  3. OPEN ALL THE TABS
    RAM Upgrade Kits for Mac
    Shop Kits
    Enough RAM
    For All The Tabs
    Shop Kits
  4. Place the battery door to the side. Using a pry tool or your fingernail, pry the battery up towards you. You have now removed the battery!
    • Place the battery door to the side.
    • Using a pry tool or your fingernail, pry the battery up towards you.
    • You have now removed the battery!
  5. Make sure when replacing the battery that the arrow on the bottom is facing down.
    • Make sure when replacing the battery that the arrow on the bottom is facing down.
Заключение
Еще один человек закончил это руководство.
Josh Forester
Участник с: 28.11.2010
2 362 Репутация
Автор 10 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 4
За всё время: 213
