Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Begin by turn the device over to it's back, with the screen facing down.
At the top of the device there is a small notch that is used to remove the battery door.
Using a pry tool or your fingernail, pry off the battery door from the main housing.
Place the battery door to the side.
Using a pry tool or your fingernail, pry the battery up towards you.
You have now removed the battery!
Remove the 6 Phillips head screws that hold the rear housing in place.
Using a spudger or plastic pry tool, slowly go around the phone between the display & rear housing to release the clips.
Using your spudger/plastic pry tool, disconnect the headphone jack flex cable.
Using your spudger/plastic pry tool, disconnect the rear speaker flex cable.
Using a spudger/pry tool, carefully remove the vibration motor from its housing. This has a mild adhesive on the bottom.
After removing both flex cables, slowly move the logic board to the left of the screen assembly.
Using your spudger/plastic pry tool, disconnect the LCD/Digitizer flex cable.
You have now removed the logic board from the display assembly.
Using a spudger/plastic pry tool lift the brown ZIF tab on the front-facing camera connector.
Carefully pull the camera out of it's connector and set to the side.
3 участников успешно повторили данное руководство.
