Введение
In this guide, you will learn how to replace the battery in your Samsung Galaxy Camera 2.
Replacing the battery of the camera can fix a number of problems, including the camera not holding a charge, the camera not charging, or the camera not powering on. Removing the battery is also a necessary step in disassembling the camera for other repairs.
Выберете то, что вам нужно
Face the camera towards you, then rotate it such that the battery door is facing up and to the right.
Locate the small latch on the right side of the camera.
Slide the latch to the left to open the battery compartment door.
Locate the battery, a black cell held in by a small clip (indicated by an outfacing arrow).
Pull the clip toward you to release the battery.
5 участников успешно повторили данное руководство.
