Запчасти
Детали не указаны.
  1. Begin removing the 3/16" screws for the device.
    • Begin removing the 3/16" screws for the device.
  2. Turn the device and remove the additional 3/16" screws.
    • Turn the device and remove the additional 3/16" screws.
  3. Turn the device and remove the additional 3/16" screw.
    • Turn the device and remove the additional 3/16" screw.
  4. Take the white cover plate off. Take the white cover plate off. Take the white cover plate off.
    • Take the white cover plate off.
  5. Using the plastic opening tools, pry open the camera from the bottom.
    • Using the plastic opening tools, pry open the camera from the bottom.
    • This may require a moderate use of force because of the sealing glue.
  6. Gently pull the connector away from the motherboard.
    • Gently pull the connector away from the motherboard.
  7. Unscrew the motherboard's screws. There are 4 3/32" screws and 3 5/32" screws.
    • Unscrew the motherboard's screws. There are 4 3/32" screws and 3 5/32" screws.
  8. Unscrew the lens' screws. There are 1 black 4/32" screw, 3 3/16" black screws, and 2 white 5/32" screws.
    • Unscrew the lens' screws. There are 1 black 4/32" screw, 3 3/16" black screws, and 2 white 5/32" screws.
  9. Pull these connectors away from motherboard.
    • Pull these connectors away from motherboard.
  10. Lift the motherboard and lens out of the case.
    • Lift the motherboard and lens out of the case.
  11. Remove all the screws circled. There is 1 1/8" screw by the flash, 1 9/32" screw that holds the flash button, 2 5/32" screw that is on the grey frame for the flash, and 2 5/32" screws that holds the cable frames on the top left.
    • Remove all the screws circled. There is 1 1/8" screw by the flash, 1 9/32" screw that holds the flash button, 2 5/32" screw that is on the grey frame for the flash, and 2 5/32" screws that holds the cable frames on the top left.
  12. Unscrew the 3 5/32" screws that cover the battery plate.
    • Unscrew the 3 5/32" screws that cover the battery plate.
  13. The black plates on the other side can be removed after these screws.
    • The black plates on the other side can be removed after these screws.
  14. Pull the flash and battery case out of the device.
    • Pull the flash and battery case out of the device.
Заключение
13 участников успешно повторили данное руководство.
Richard Hicks
Участник с: 13.01.2015
1 262 Репутация
Автор 4 руководств
Команда
USF Tampa, Team 1-3, Sullivan Winter 2015 Участник USF Tampa, Team 1-3, Sullivan Winter 2015
USFT-SULLIVAN-W15S1G3
3 членов
Автор 4 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 707
