Выберете то, что вам нужно
Шаг 1 Screen
Careful: steps 1-6 are sourced from a guide that's marked as in-progress.
Begin removing the 3/16" screws for the device.
Gently pull the connector away from the motherboard.
Help! I can't get this connector back in place! How did you do it?
Thanks!
Got it finally - and it's working again, I can't believe it! Thank you so much for the instructions!!!!
Unscrew the motherboard's screws. There are 4 3/32" screws and 3 5/32" screws.
Unscrew the lens' screws. There are 1 black 4/32" screw, 3 3/16" black screws, and 2 white 5/32" screws.
This seems to be wrong. Only 2 screws connect the lens to the camera body - if you unscrew the others, you open up the lens and there is no need to do so.
10 участников успешно повторили данное руководство.
