Samsung Galaxy Camera Lens and Motherboard Replacement
Выберете то, что вам нужно
  1. Careful: steps 1-6 are sourced from a guide that's marked as in-progress.
    Samsung Galaxy Camera Lens and Motherboard Replacement, Screen: шаг 1, изображение 1 из 1
    • Begin removing the 3/16" screws for the device.
  2. Samsung Galaxy Camera Lens and Motherboard Replacement: шаг 2, изображение 1 из 1
    • Turn the device and remove the additional 3/16" screws.
  3. Samsung Galaxy Camera Lens and Motherboard Replacement: шаг 3, изображение 1 из 1
    • Turn the device and remove the additional 3/16" screw.
  4. Samsung Galaxy Camera Lens and Motherboard Replacement: шаг 4, изображение 1 из 3 Samsung Galaxy Camera Lens and Motherboard Replacement: шаг 4, изображение 2 из 3 Samsung Galaxy Camera Lens and Motherboard Replacement: шаг 4, изображение 3 из 3
    • Take the white cover plate off.
  5. Samsung Galaxy Camera Lens and Motherboard Replacement: шаг 5, изображение 1 из 1
    • Using the plastic opening tools, pry open the camera from the bottom.
    • This may require a moderate use of force because of the sealing glue.
  6. Samsung Galaxy Camera Lens and Motherboard Replacement: шаг 6, изображение 1 из 1
    • Gently pull the connector away from the motherboard.
    Help! I can't get this connector back in place! How did you do it?
    Thanks!
    rotraut geringer - Ответить
    Got it finally - and it's working again, I can't believe it! Thank you so much for the instructions!!!!
  7. Samsung Galaxy Camera Lens and Motherboard Replacement, Lens and Motherboard: шаг 7, изображение 1 из 1
    • Unscrew the motherboard's screws. There are 4 3/32" screws and 3 5/32" screws.
  8. Samsung Galaxy Camera Lens and Motherboard Replacement: шаг 8, изображение 1 из 1
    • Unscrew the lens' screws. There are 1 black 4/32" screw, 3 3/16" black screws, and 2 white 5/32" screws.
    This seems to be wrong. Only 2 screws connect the lens to the camera body - if you unscrew the others, you open up the lens and there is no need to do so.
    NOVOMOTION J. H. - Ответить
  9. Samsung Galaxy Camera Lens and Motherboard Replacement: шаг 9, изображение 1 из 1
    • Pull these connectors away from motherboard.
  10. Samsung Galaxy Camera Lens and Motherboard Replacement: шаг 10, изображение 1 из 1
    • Lift the motherboard and lens out of the case.
Заключение
10 участников успешно повторили данное руководство.
Richard Hicks
Участник с: 01/13/15
1 262 Репутация
Автор 4 руководств
Команда
USF Tampa, Team 1-3, Sullivan Winter 2015 Участник USF Tampa, Team 1-3, Sullivan Winter 2015
USFT-SULLIVAN-W15S1G3
3 членов
Автор 4 руководств
Один комментарий
Hey mate, what do you do after the motherboard replacement? Just turn the camera on? Do you need to do a master reset?
Sam - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 12
За всё время: 4,995
