Запчасти
Детали не указаны.
  1. Begin removing the 3/16" screws for the device.
    • Begin removing the 3/16" screws for the device.
  2. Turn the device and remove the additional 3/16" screws.
    • Turn the device and remove the additional 3/16" screws.
  3. Turn the device and remove the additional 3/16" screw.
    • Turn the device and remove the additional 3/16" screw.
  4. Take the white cover plate off. Take the white cover plate off. Take the white cover plate off.
    • Take the white cover plate off.
  5. Using the plastic opening tools, pry open the camera from the bottom.
    • Using the plastic opening tools, pry open the camera from the bottom.
    • This may require a moderate use of force because of the sealing glue.
  6. Gently pull the connector away from the motherboard.
    • Gently pull the connector away from the motherboard.
Заключение
7 участников успешно повторили данное руководство.
Richard Hicks
Участник с: 13.01.2015
1 262 Репутация
Автор 4 руководств
Команда
USF Tampa, Team 1-3, Sullivan Winter 2015 Участник USF Tampa, Team 1-3, Sullivan Winter 2015
USFT-SULLIVAN-W15S1G3
3 членов
Автор 4 руководств
Один комментарий
Fix cannot connect to camera error
Robert Spencer - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 907
