Введение
Are you having any kind of software problems that cannot be fixed digitally? Replacing the motherboard should do the trick.
Выберете то, что вам нужно
Locate the indent area highlighted in red and use either your fingernail or a Prying Tool (such as a guitar pick) to separate the back from the body of the phone.
Once the cover is removed, locate the battery that reads "SAMSUNG."
Use either your fingernail or a Plastic Prying Tool (such as a guitar pick) to lift up the bottom indent of the battery.
Use a Thin Plastic Tool (such as a guitar pick) or Plastic Prying Tool (such as a spudger) to lift out the glass digitizer and LCD screen around the edges.
Using a spudger to remove the black plastic pieces on the top and bottom of the screen.
Use a spudger to slowly lift up the motherboard and remove it from the plastic frame.
2 участников успешно повторили данное руководство.
