Samsung Galaxy Express 3 Rear Camera Lens Replacement
Выберете то, что вам нужно
  1. Samsung Galaxy Express 3 Rear Camera Lens Replacement, Battery: шаг 1, изображение 1 из 2 Samsung Galaxy Express 3 Rear Camera Lens Replacement, Battery: шаг 1, изображение 2 из 2
    • Locate the indent area highlighted in red and use either your fingernail or a Prying Tool (such as a guitar pick) to separate the back from the body of the phone.
  2. Samsung Galaxy Express 3 Rear Camera Lens Replacement: шаг 2, изображение 1 из 3 Samsung Galaxy Express 3 Rear Camera Lens Replacement: шаг 2, изображение 2 из 3 Samsung Galaxy Express 3 Rear Camera Lens Replacement: шаг 2, изображение 3 из 3
    • Once the cover is removed, locate the battery that reads "SAMSUNG."
    • Use either your fingernail or a Plastic Prying Tool (such as a guitar pick) to lift up the bottom indent of the battery.
    • Do not use a metal tool, as it can cause injury.
  3. Samsung Galaxy Express 3 Rear Camera Lens Replacement, Rear Camera Lens: шаг 3, изображение 1 из 1
    • Carefully push a small pointed tool such as a plastic opening tool (or metal spudger if needed) underneath the camera lens in a corner.
    • Pry up each corner of the lens.
    • Be careful, especially if using the metal spudger, as if you push to hard it can cause damage to the device or yourself.
  4. Samsung Galaxy Express 3 Rear Camera Lens Replacement: шаг 4, изображение 1 из 2 Samsung Galaxy Express 3 Rear Camera Lens Replacement: шаг 4, изображение 2 из 2
    • Slide your tool underneath one corner to the other to release the lens.
    • Make sure not to insert your tool too far as it can damage the camera.
    • When putting the new lens in make sure not to put to much force on it as it can break again.
Заключение
Mack Johnson
Участник с: 04/05/18
984 Репутация
Автор 6 руководств
Команда
Linn Benton Community College, Team S2-G4, Johnson Spring 2018 Участник Linn Benton Community College, Team S2-G4, Johnson Spring 2018
LBCC-JOHNSON-S18S2G4
4 членов
Автор 7 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 5
За всё время: 468
