Samsung Galaxy Gear Display Assembly Replacement
Выберете то, что вам нужно
  1. Samsung Galaxy Gear Display Assembly Replacement, Display Housing: шаг 1, изображение 1 из 1
    • Use a T5 Torx screwdriver to remove the four 4.0 mm screws on the back of the device.
    • Be sure your device is turned off.
  2. Samsung Galaxy Gear Display Assembly Replacement: шаг 2, изображение 1 из 1
    • Use a plastic opening tool to separate the display housing from from the device.
    • To ensure you don't damage your device, insert the opening tool and slide it the entire length of the gap on both sides of the device.
  3. Samsung Galaxy Gear Display Assembly Replacement: шаг 3, изображение 1 из 2 Samsung Galaxy Gear Display Assembly Replacement: шаг 3, изображение 2 из 2
    • Gently pry back the metal flap on top of the connector.
    • Locate the two 2.0 mm black screws and unscrew using a Phillips PH00 bit. The connector will detach from the device.
  4. Samsung Galaxy Gear Display Assembly Replacement, Motherboard: шаг 4, изображение 1 из 2 Samsung Galaxy Gear Display Assembly Replacement, Motherboard: шаг 4, изображение 2 из 2
    • On the display, use a plastic opening tool to lift up the two ribbon cables the motherboard.
  5. Samsung Galaxy Gear Display Assembly Replacement: шаг 5, изображение 1 из 1
    • The motherboard is attached to the display using an adhesive
    • Using a heat gun, heat up the display for 4 to 5 minutes, making sure the move the heat gun around to distribute the heat around the display. This heats up the adhesive making the motherboard easier to remove
  6. Samsung Galaxy Gear Display Assembly Replacement: шаг 6, изображение 1 из 2 Samsung Galaxy Gear Display Assembly Replacement: шаг 6, изображение 2 из 2
    • Using a plastic opening tool, carefully insert the opening tool in between the bezel and the motherboard and slide it the entire length of the logic board.
    • Slowly pry up the motherboard from the display.
  7. Samsung Galaxy Gear Display Assembly Replacement, Display Assembly: шаг 7, изображение 1 из 1
    • The display assembly is now separated and can be replaced
Заключение
2 участников успешно повторили данное руководство.
Joe
Участник с: 04/11/16
279 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 1-9, Maness Spring 2016 Участник Cal Poly, Team 1-9, Maness Spring 2016
CPSU-MANESS-S16S1G9
4 членов
Автор 7 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 4
За всё время: 1,548
