Samsung Galaxy Grand Prime Headphone Jack and Loudspeaker Replacement
Выберете то, что вам нужно
  1. Samsung Galaxy Grand Prime Headphone Jack and Loudspeaker Replacement, Removing back cover: шаг 1, изображение 1 из 1
    • Insert an opening tool or fingernail into the tab on the power button side of the phone.
    • Lift on the tab to pry the back cover off of the phone.
    • Continue to pry off the back all around the edges of the phone until the entire cover is fully removed.
  2. Samsung Galaxy Grand Prime Headphone Jack and Loudspeaker Replacement, Remove The Battery: шаг 2, изображение 1 из 1
    • To remove the battery, lift up on the thumb tab located on the bottom right corner of battery bay.
  3. Samsung Galaxy Grand Prime Headphone Jack and Loudspeaker Replacement, Remove The SD And LCD Ribbon Cable: шаг 3, изображение 1 из 2 Samsung Galaxy Grand Prime Headphone Jack and Loudspeaker Replacement, Remove The SD And LCD Ribbon Cable: шаг 3, изображение 2 из 2
    • To remove the SD card and Sim card, look above the battery bay and slide the card out.
    • Insert an opening tool to lift up and the plastic plate that covers the LCD ribbon cable and remove it.
  4. Samsung Galaxy Grand Prime Headphone Jack and Loudspeaker Replacement, Removing screws: шаг 4, изображение 1 из 1
    • Use a size PH000 Phillips screwdriver to unscrew the nine screws located on the back.
    • Keep the screws on a magnetic mat or in a secure location.
  5. Samsung Galaxy Grand Prime Headphone Jack and Loudspeaker Replacement, Seperating Bezel and Screen: шаг 5, изображение 1 из 2 Samsung Galaxy Grand Prime Headphone Jack and Loudspeaker Replacement, Seperating Bezel and Screen: шаг 5, изображение 2 из 2
    • Use a heat gun or a heating device to lightly heat the edges of the screen on the phone
    • Insert an opening tool between the screen and plastic bezel, then apply pressure to separate.
    • You can also push the screen out in the empty slot where the battery was to separate.
    • It is important to be quick but careful when separating the screen and plastic bezel because the glue could cool down and re-bond the two parts.
  6. Samsung Galaxy Grand Prime Headphone Jack and Loudspeaker Replacement: шаг 6, изображение 1 из 2 Samsung Galaxy Grand Prime Headphone Jack and Loudspeaker Replacement: шаг 6, изображение 2 из 2
    • Use a plastic spudger to disconnect the ribbon cable from the loudspeaker unit.
    • Lift from the top of the loudspeaker unit to release from the phone.
    • You do not need to remove the motherboard to do this.
Заключение
3 участников успешно повторили данное руководство.
Alex Boyle
Участник с: 07/31/18
374 Репутация
Автор 3 руководств
Команда
UW Tacoma, Team S1-G1, Liner Summer 2018 Участник UW Tacoma, Team S1-G1, Liner Summer 2018
UWT-LINER-SU18S1G1
5 членов
Автор 5 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 18
За всё время: 1,379
