Введение
This repair is need to replace a bad audio jack or speaker.
Выберете то, что вам нужно
Remove the back cover of phone by lifting up on the back cover tab with the blue plastic opening tool.
Go around the edge of the back cover to completely remove it.
Remove the old battery by lifting up on the thumb tab.
Periodically clean the brass terminals on the battery and the phone. Place a minute amount of ISO on a Q-tip and gingerly clean the connections.
Remove the nine 4mm screws screws from the midframe with a Phillips #000 screwdriver.
Wedge the blue plastic opening tool in between the front and side panel.
Move the blue plastic opening tool around the edges between the front and side panel.
Unhook the ribbon cable clip with the plastic opening tool and remove the audio jack.
29 участников успешно повторили данное руководство.
3 Комментариев
i seem to find myself with the speaker of microphone connected to the back of the housing.. where as i see your photo in step 5 does't have this. how can I replace this element?
I do this but i think my circuit have problem. When i insert aux, the sound play mono. The phone setting is stereo…..
How can i fix this problem?
Replay me on rabbanihootan71@gmail.com
How to me a memory card a default storage on grand prime
