Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement
Выберете то, что вам нужно
  1. Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Battery: шаг 1, изображение 1 из 3 Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Battery: шаг 1, изображение 2 из 3 Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Battery: шаг 1, изображение 3 из 3
    • Remove the back cover of phone by lifting up on the back cover tab with the blue plastic opening tool.
    • Go around the edge of the back cover to completely remove it.
  2. Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Remove the battery.: шаг 2, изображение 1 из 3 Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Remove the battery.: шаг 2, изображение 2 из 3 Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Remove the battery.: шаг 2, изображение 3 из 3
    • Remove the old battery by lifting up on the thumb tab.
    • Periodically clean the brass terminals on the battery and the phone. Place a minute amount of ISO on a Q-tip and gingerly clean the connections.
  3. Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Midframe: шаг 3, изображение 1 из 3 Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Midframe: шаг 3, изображение 2 из 3 Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Midframe: шаг 3, изображение 3 из 3
    • Remove the nine 4mm screws screws from the midframe with a Phillips #000 screwdriver.
  4. Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement: шаг 4, изображение 1 из 2 Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement: шаг 4, изображение 2 из 2
    • Wedge the blue plastic opening tool in between the front and side panel.
    • Move the blue plastic opening tool around the edges between the front and side panel.
  5. Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement: шаг 5, изображение 1 из 2 Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement: шаг 5, изображение 2 из 2
    • Make sure that you detach the mid-frame from the inside too.
  6. Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Headphone Jack/Speaker Assembly: шаг 6, изображение 1 из 2 Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Headphone Jack/Speaker Assembly: шаг 6, изображение 2 из 2
    • Unhook the ribbon cable clip with the plastic opening tool and remove the audio jack.
Заключение
30 участников успешно повторили данное руководство.
Kyle Ruff
Участник с: 02/04/16
6 725 Репутация
Автор 5 руководств
Команда
USF Tampa, Team 17-3, Blackwell Winter 2016 Участник USF Tampa, Team 17-3, Blackwell Winter 2016
USFT-BLACKWELL-W16S17G3
3 членов
Автор 12 руководств
3 Комментариев
i seem to find myself with the speaker of microphone connected to the back of the housing.. where as i see your photo in step 5 does't have this. how can I replace this element?
jennpindakaas - Ответить
I do this but i think my circuit have problem. When i insert aux, the sound play mono. The phone setting is stereo…..
How can i fix this problem?
Replay me on rabbanihootan71@gmail.com
Hootan Rabbani - Ответить
How to me a memory card a default storage on grand prime
Ayandaundetsco - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 15
За последние 30 дней: 30
За всё время: 35,959
