Введение
How to disassemble and replace the Touch screen digitizer and the LCD display.
Выберете то, что вам нужно
Видео обзор
Here we have Samsung Galaxy J1 with broken glass and screen.
We will replace the touch screen and the LCD.
First remove the battery and any installed SIM and memory cards.
Under this plastic is the LCD flex cable connector.
Use a tool with a needlepoint and remove it.
Use hot air to warm the glass and to make adhesive soften.
With a cutter or knife start the separation.
When you have enough space between the glass and the frame, continue with a plastic tool.
You can warm the glass again to make the separation more easy.
Finally remove the screen and the glass from the frame.
If you want to change only the glass, disconnect the touch screen flex cable and gently separate the glass from the LCD.
Connect the touch screen to the LCD flex cable.
Put the LCD and the screen in their place.
Remove the protector from the touch screen.
Remove the protector from the LCD (if it's new).
Connect the LCD flex cable and you are ready.
I put a new screen on the phone but when I turn it on the screen is still black with light up lines. What can I do to make the phone work
113 участников успешно повторили данное руководство.
24 Комментариев
Thank you ifixit
How much is the cost for Galaxy J1 replacement glass?
It costs from 18€ up to 25€.
Gracias bro .. se ve interesante el único problema es que no se muy bien el ingles
Hello!Need wholesale LCD screen?https://txlcd.com/
Samnsung j1 SM-j111M
I can't find replacemnt for Samnsung j1 SM-j111M?
do you know what model it is compatible with it?
Not charge contineu
Why is it that replacing the touch and LCD is so expensive
Why is it that
I have put a new screen on my friends Samsung galaxy J1 but it won't turn on and when it dose I'll see are lines. What do I do?
Very helpful, thank you!
Is J1 LCD is compatible with J1 Ace model J110H ?
Samsung j1ace full screen replacement
thank for posting, genial consejo
