Введение
If you need to remove the midframe to gain access to internal components such as the motherboard, front camera, rear camera, and daughterboard, this guide will do the trick!
Выберете то, что вам нужно
Insert a finger nail or plastic opening tool between the back cover and the device.
Gently pry the rear cover off of the back of the phone.
Insert a plastic opening tool between the screen and the back of the device.
Starting at the bottom of the device, gently slide the tool along the edges of the screen.
Gently pry the main assembly from the midframe of the device.
6 участников успешно повторили данное руководство.
