Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
This guide will assist in the replacement of the Samsung Galaxy J1's volume button.
Запчасти
Детали не указаны.
  1. Insert a finger nail or plastic opening tool between the back cover and the device.
    • Insert a finger nail or plastic opening tool between the back cover and the device.
    • Gently pry the rear cover off of the back of the phone.
  2. Using a finger, pull the SIM card down out of its slot. Remove the SIM card.
    • Using a finger, pull the SIM card down out of its slot.
    • Remove the SIM card.
    • The pictured device is missing the SIM card and battery.
  3. Using a Phillips #00 screwdriver remove the eleven 3 mm screws.
    • Using a Phillips #00 screwdriver remove the eleven 3 mm screws.
  4. Insert a plastic opening tool between the screen and the back of the device. Starting at the bottom of the device, gently slide the tool along the edges of the screen. Gently pry the main assembly from the midframe of the device.
    • Insert a plastic opening tool between the screen and the back of the device.
    • Starting at the bottom of the device, gently slide the tool along the edges of the screen.
    • Gently pry the main assembly from the midframe of the device.
    • When removing the main assembly, pry gently so as to not crack the glass screen or break any clips within the device.
  5. Use the flat edge of a spudger to push the volume button out. Remove the volume button.
    • Use the flat edge of a spudger to push the volume button out.
    • Remove the volume button.
Заключение
4 участников успешно повторили данное руководство.
Sean Kramer
Участник с: 14.02.2018
1 263 Репутация
Автор 6 руководств
Команда
USF Tampa, Team S5-G4, Eyestone Spring 2018 Участник USF Tampa, Team S5-G4, Eyestone Spring 2018
USFT-EYESTONE-S18S5G4
3 членов
Автор 6 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 4
За последние 30 дней: 25
За всё время: 984
