Введение
If you are having trouble with connecting earphones or headphones to your phone it may be due to the headphone jack being faulty. This guide will show the step by step process of changing out the headphone jack on the Samsung Galaxy J3 Luna Pro.
Запчасти
Никакие детали не требуются.
  1. Turn off the phone.
    • Turn off the phone.
    • Remove the back cover and battery
  2. Attach a suction cup to the screen and pry upwards. Insert the plastic opening tool into the gap under the screen and work your way around the perimeter. Don't remove the screen completely as there are cables still connection the two pieces.
    • Attach a suction cup to the screen and pry upwards.
    • Insert the plastic opening tool into the gap under the screen and work your way around the perimeter.
    • Don't remove the screen completely as there are cables still connection the two pieces.
  3. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  4. Use the pointy end of a spudger to remove the white plastic cover from the display cover. Use the spudger to pry up the display cable from the motherboard. Remove the screen.
    • Use the pointy end of a spudger to remove the white plastic cover from the display cover.
    • Use the spudger to pry up the display cable from the motherboard.
    • Remove the screen.
  5. Remove the eleven JIS 00 screws from the mid-frame. Using a spudger, pry the mid-frame from the screen. Using a spudger, pry the mid-frame from the screen.
    • Remove the eleven JIS 00 screws from the mid-frame.
    • Using a spudger, pry the mid-frame from the screen.
  6. Remove the motherboard from the mid-frame. Remove the motherboard from the mid-frame. Remove the motherboard from the mid-frame.
    • Remove the motherboard from the mid-frame.
  7. Use the flat end of a spudger to pry up the headphone jack cable connector from its socket on the motherboard. Use the flat end of a spudger to pry up the headphone jack cable connector from its socket on the motherboard.
    • Use the flat end of a spudger to pry up the headphone jack cable connector from its socket on the motherboard.
Заключение
Brandon Mendoza
Участник с: 29.01.2018
379 Репутация
Автор 2 руководств
Команда
USF Tampa, Team S5-G5, Passmore Spring 2018 Member of USF Tampa, Team S5-G5, Passmore Spring 2018
USFT-PASSMORE-S18S5G5
5 членов
Автор 5 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 2
За 7 дней: 8
За 30 дней: 31
За всё время: 380
