Введение
The plastic covering over the camera can sometimes crack or break off completely. This guide will show you how to replace the middle frame bezel including the camera cover.
Выберете то, что вам нужно
Separate the back casing from the phone by carefully using your fingers to pry it apart.
Remove all 11 screws by using the J000 phillips head from the 64 Bit Driver Kit.
Use the flat side of the metal spudger to remove the middle frame bezel, and replace.
6 участников успешно повторили данное руководство.
