Введение
This guide will walk you through the process of replacing a not working headphone jack in a Samsung Galaxy J3V.
Выберете то, что вам нужно
Place your thumb on the top left corner and pry the tab open and lift off the back cover.
Use a small suction cup to pull the screen up. Then slip a small plastic opening tool under the screen to pry it upwards.
Remove connector tab with spudger then carefully remove headphone jack with tweezers.
