Введение
Hi guys, am Dorcas Obayemi. Welcome to my page .Creating a guide to help anyone fix/replace the charging port of Samsung Galaxy J4 with ease.
If you have any problem or want to add something drop a comment
Выберете то, что вам нужно
Dissemble the phone
Open back cover and remove the battery
Remove the nuts with the aid of a screw driver.
Remove the panel and recognize where the charging port is.
With the use of an opening tool remove the panel carefully.
Get you new charging port and fix it legs on the panel.
Use hot air or soldering iron along side with a tweezers to remove the charging port.
Making use of the hot air not soldering iron to fix the new charging port.
Boom you’re done replacing the charging port so place the panel back, screw the nut back and juice your phone.
6 участников успешно повторили данное руководство.
3 Комментариев
Wow. Thanks for this contribution.
Incredible I believe this gonna help one replace charging port perfectly
