Введение
This guide will help you replace a cracked or broken screen on your Samsung Galaxy J7.
Выберете то, что вам нужно
Pull out the battery by pulling on the bottom left slit under the battery.
Lift up the back of the device with the iFixit opening tool and disconnect it from the front.
Gently lift up the speaker piece and disconnect it from the panel.
Gently lift up the tab of the motor.
Remove the motor from the panel completely to disconnect it.
9 участников успешно повторили данное руководство.
