Samsung Galaxy J7 V Earpiece Speaker Replacement
Выберете то, что вам нужно
  1. Samsung Galaxy J7 V Earpiece Speaker Replacement, Screen: шаг 1, изображение 1 из 1
    • Be very careful during this step. The OLED (organic light-emitting diode) display is very fragile and can break easily.
    • Insert a Jimmy tool under one of the corners of the display and gently raise the display.
  2. Samsung Galaxy J7 V Earpiece Speaker Replacement: шаг 2, изображение 1 из 1
    • Gently slide the Jimmy tool around the entire perimeter of the phone.
  3. Samsung Galaxy J7 V Earpiece Speaker Replacement: шаг 3, изображение 1 из 1
    • Be extra careful with the display's ribbon cables. They are fragile.
    • Carefully lift the display to remove it.
  4. Samsung Galaxy J7 V Earpiece Speaker Replacement, Home button: шаг 4, изображение 1 из 1
    • Locate the socket of the home button.
    • Fit the metal spudger in between the socket and the home button.
  5. Samsung Galaxy J7 V Earpiece Speaker Replacement: шаг 5, изображение 1 из 1
    • Take the metal spudger and slide it underneath the home button.
    • Lift up until the home button is removed from its socket.
  6. Samsung Galaxy J7 V Earpiece Speaker Replacement, Motherboard: шаг 6, изображение 1 из 1
    • Remove fourteen screws from the midframe using a Phillips #00 screwdriver.
  7. Samsung Galaxy J7 V Earpiece Speaker Replacement: шаг 7, изображение 1 из 1
    • Flip the phone to the back side where the battery was removed.
    • Apply pressure with your hands to pop the midframe off.
  8. Samsung Galaxy J7 V Earpiece Speaker Replacement: шаг 8, изображение 1 из 2 Samsung Galaxy J7 V Earpiece Speaker Replacement: шаг 8, изображение 2 из 2
    • Flip the phone back over.
    • Remove the single black screw from the motherboard using a Phillips #00 screwdriver.
    • Place a few iFixit opening picks beneath the motherboard.
    • Spread the opening picks evenly around the motherboard to ensure it does not bend as you remove it.
    • Lift the motherboard using the iFixit opening picks.
  9. Samsung Galaxy J7 V Earpiece Speaker Replacement, Earpiece Speaker: шаг 9, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    Купить
    • Use the tweezers to remove the back of the earpiece speaker.
Заключение
3 участников успешно повторили данное руководство.
Ella Hamm
Участник с: 02/08/22
154 Репутация
1 руководство автора
Команда
University of Kentucky, Team 1-5, Kaufmann Spring 2022 Участник University of Kentucky, Team 1-5, Kaufmann Spring 2022
UKY-KAUFMANN-S22S1G5
3 членов
Автор 3 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 6
За последние 30 дней: 42
За всё время: 719
