Введение
This guide is a step by step instruction on how to replace the rear camera in your Samsung Galaxy J7 V smartphone. Before you begin make sure you have all the tools necessary and set aside the recommended amount of time to complete the repair.
Выберете то, что вам нужно
Insert a Jimmy tool under one of the corners of the display and gently raise the display.
Locate the socket of the home button.
Fit the metal spudger in between the socket and the home button.
Take the metal spudger and slide it underneath the home button.
Lift up until the home button is removed from its socket.
Use the indent on the right side of the phone to lift up the backing
With the phone faced downwards, remove the backing of the case, lifting up from the right side
Carefully remove the battery by lifting the bottom side, and then fully remove the battery
Remove fourteen screws from the midframe using a Phillips #00 screwdriver.
Flip the phone to the back side where the battery was removed.
Apply pressure with your hands to pop the midframe off.
Flip the phone back over.
Remove the single black screw from the motherboard using a Phillips #00 screwdriver.
Place a few iFixit opening picks beneath the motherboard.
Lift the motherboard using the iFixit opening picks.
2 участников успешно повторили данное руководство.
