Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
This guide instructs on how to replace the motherboard.
Запчасти
Детали не указаны.
  1. Before starting, ensure device is completely turned off. On the back of phone, locate the slot on the top left corner. Insert plastic opening tool or fingernail and pull up on the back plate.
    • Before starting, ensure device is completely turned off.
    • On the back of phone, locate the slot on the top left corner.
    • Insert plastic opening tool or fingernail and pull up on the back plate.
    • With the corner released, slide your finger around the device between the back plate and the phone to release connectors.
    Bonjur vule vondre de telefon samsung galaxy mega ecron
    bucuresteanugigel - Ответить
    0751571718 samsung galaxi mega
  2. Insert fingernail into the slot on bottom of battery and gently pull up. Remove the battery. Remove the battery.
    • Insert fingernail into the slot on bottom of battery and gently pull up.
    • Remove the battery.
  3. Remove the 14 3.45 mm Phillips #000 screws from the assembly. Gently, insert plastic opening tool into seam above the volume buttons of your phone. You may substitute metal spudger for plastic opening tool to first start the opening of the seam. This may cause exterior cosmetic damage.
    • Remove the 14 3.45 mm Phillips #000 screws from the assembly.
    • Gently, insert plastic opening tool into seam above the volume buttons of your phone.
    • You may substitute metal spudger for plastic opening tool to first start the opening of the seam. This may cause exterior cosmetic damage.
    If you insert a spudger from the battery compartment seam, you can start the opening without damage to the outside.
    Ted - Ответить
  4. Slowly slide plastic opening tool around the device to release all the connectors internal to the device. The device should easily come apart after the plastic opening tool is slid around the entire device.
    • Slowly slide plastic opening tool around the device to release all the connectors internal to the device.
    • The device should easily come apart after the plastic opening tool is slid around the entire device.
    • During reassembly, ensure volume and power buttons align properly.
  5. Remove the 2.55 mm Phillips #000 screw from the motherboard panel.
    • Remove the 2.55 mm Phillips #000 screw from the motherboard panel.
  6. Remove the connector clips on motherboard. Remove the connector clips on motherboard. Remove the connector clips on motherboard.
    • Remove the connector clips on motherboard.
  7. Remove the final motherboard connectors. Remove the final motherboard connectors.
    • Remove the final motherboard connectors.
  8. Lift motherboard gently with finger. There is a total of six connectors on the motherboard that need to be removed. All of them are shown in the pictures in this guide, make sure all of them are disconnected before removing. There is a total of six connectors on the motherboard that need to be removed. All of them are shown in the pictures in this guide, make sure all of them are disconnected before removing.
    • Lift motherboard gently with finger.
    • There is a total of six connectors on the motherboard that need to be removed. All of them are shown in the pictures in this guide, make sure all of them are disconnected before removing.
Заключение
7 участников успешно повторили данное руководство.
Max Rathman
Участник с: 04.02.2016
843 Репутация
Автор 4 руководств
Команда
USF Tampa, Team 17-2, Blackwell Winter 2016 Участник USF Tampa, Team 17-2, Blackwell Winter 2016
USFT-BLACKWELL-W16S17G2
4 членов
Автор 8 руководств
Комментариев: 4
Where can I buy a motherboard replacement for Mega 6.3 GT-I9205/I527?
valuesphilippines - Ответить
Is there an international market to buy mobile phone hardware? I can not find motherboard for this phone in my country (online).
lukhman - Ответить
Where can I buy the motherboard replacement for G. Mega 6.3 19200
Thats dae - Ответить
i cant turn on my galay mega 6.3 afrer update phone is like DEAD!!!  please help me…..for Samsung mega gt-i9205
mirza baig - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 8
За всё время: 5,084
