Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This guide instructs on how to replace the motherboard.
Выберете то, что вам нужно
Before starting, ensure device is completely turned off.
On the back of phone, locate the slot on the top left corner.
Insert plastic opening tool or fingernail and pull up on the back plate.
With the corner released, slide your finger around the device between the back plate and the phone to release connectors.
Insert fingernail into the slot on bottom of battery and gently pull up.
Remove the battery.
Remove the 14 3.45 mm Phillips #000 screws from the assembly.
Gently, insert plastic opening tool into seam above the volume buttons of your phone.
Slowly slide plastic opening tool around the device to release all the connectors internal to the device.
The device should easily come apart after the plastic opening tool is slid around the entire device.
10 участников успешно повторили данное руководство.
5 Комментариев
Where can I buy a motherboard replacement for Mega 6.3 GT-I9205/I527?
i cant turn on my galay mega 6.3 afrer update phone is like DEAD!!! please help me…..for Samsung mega gt-i9205
This app is the best
