Введение
Use this guide to replace the motherboard in your Samsung Galaxy Nexus
Выберете то, что вам нужно
You must open the back of the phone to access the battery. To do this use the plastic opening tools or your fingernail and insert it into the divot.
Remove the back cover of the phone by moving the prying tool or your fingernail away from the phone while it is still in the divot.
Insert your finger into the divot of the battery and pull the battery towards yourself to remove.
This is when a new battery will be inserted.
Remove 4.4 mm screws using a PH # 000 as indicated on the picture.
This is something that cannot be fixed. Due to it being a prerequisite guide it comes up with the title of the guide itself as it is inserted as a prerequisite guide.
After removing the screws be sure to turn the phone right side up.
Insert your plastic opening tool between the screen and the outer case. Move the opening tool around the phone without removing it from in between the screen and the shell of the phone.
Unscrew 4.4mm with a PH #000 marked screw.
Peel the display connector strip off the main circuit board using the tweezers.
Peel the USB connector strip off the main circuit board using the tweezers.
Using tweezers, pull the top circuit board off.
4 участников успешно повторили данное руководство.
2 Комментариев
were i can find mother board i need the mother board
