Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This guide will teach you how to replace a nonfunctional battery in your Samsung Galaxy Note 10.1 2014 edition.
Выберете то, что вам нужно
Инструмент, используемый на этом этапе:Spudger$2.99
Using the nylon spudger or plastic opening tool along the edges of the screen, separate the back case off of the device.
Place your finger on the thin black bar at the end of the ribbon tape and flip each one up.
Gently pull the ribbon tape on the battery away from the bar. Repeat this process for the second ribbon tape.
Инструмент, используемый на этом этапе:Phillips #000 Screwdriver$5.49
Remove the six 3mm screws around the battery with the Phillips PH000 screwdriver.
Lift up the battery from the bottom and situate the black nylon spudger underneath the battery.
Use the black nylon spudger to disconnect the multi-colored wires from the rest of the device.
26 участников успешно повторили данное руководство.
5 Комментариев
Just followed your instructions. Used a online kit with a guitar pick-like spudger. Had to wrestle with it slightly, but everything worked out perfectly to your instructions.
You said it was like a guitar pick so I used a guitar pick. Worked pretty well. Guitar pick is bent up but they are cheap.
Something I won’t be doing again. It was very annoying to do and nerve racking to complete. Was a pain to snap back together.
