Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This guide will teach you how to replace the defective or nonfunctional battery in your Samsung Galaxy Note 10.1 2014 edition.
Выберете то, что вам нужно
Инструмент, используемый на этом этапе:Spudger$2.99
Using the nylon spudger or plastic opening tool along the edges of the screen, separate the back case off of the device.
Remove the three 3mm screws on the top right side of the device with the Phillips PH000 screw head.
Remove the one 3mm screw on the top left side of the device with the same method.
Remove the gray rubber piece.
Use a spudger or fingernail to disconnect the blue antenna cable from the motherboard.
Remove the right speaker unit.
Remove the loudspeaker modules located on the parts where the screws were removed by using the black nylon spudger.
4 участников успешно повторили данное руководство.
