Samsung Galaxy Note 4 Antenna Replacement
Выберете то, что вам нужно
  1. Samsung Galaxy Note 4 Antenna Replacement, Midframe: шаг 1, изображение 1 из 1
    • Remove the sixteen 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
    • Grasp the cap of the S Pen and remove it from its slot in the midframe.
  2. Samsung Galaxy Note 4 Antenna Replacement: шаг 2, изображение 1 из 3 Samsung Galaxy Note 4 Antenna Replacement: шаг 2, изображение 2 из 3 Samsung Galaxy Note 4 Antenna Replacement: шаг 2, изображение 3 из 3
    • Insert a plastic opening tool between the midframe and the display assembly.
    • Work the plastic opening tool around the perimeter of the phone to break the adhesive.
    • This adhesive is relatively weak, so no heat gun should be necessary.
    • Be careful to not separate the front glass panel from the rest of the display assembly, as it is still held together with adhesive.
  3. Samsung Galaxy Note 4 Antenna Replacement: шаг 3, изображение 1 из 1
    • Use a plastic opening tool to loosen the clasps around the battery housing.
  4. Samsung Galaxy Note 4 Antenna Replacement: шаг 4, изображение 1 из 3 Samsung Galaxy Note 4 Antenna Replacement: шаг 4, изображение 2 из 3 Samsung Galaxy Note 4 Antenna Replacement: шаг 4, изображение 3 из 3
    • Push on the battery housing to separate the midframe from the display assembly.
    • You will have to apply a reasonable amount of pressure to separate the two parts.
    • If your new midframe does not come with a headphone jack assembly, you'll need to transfer the one from the old midframe into the new one. It can be pried loose with plastic opening tools, as it is held in place with several plastic pins.
  5. Samsung Galaxy Note 4 Antenna Replacement, Detaching Antenna Connectors: шаг 5, изображение 1 из 2 Samsung Galaxy Note 4 Antenna Replacement, Detaching Antenna Connectors: шаг 5, изображение 2 из 2
    • Pull up on the connectors with tweezers to detach them from the phone.
    • The blue dot on the shorter connector belongs nearest the bottom of the phone.
Заключение
19 участников успешно повторили данное руководство.
Derek Nola
Участник с: 01/06/15
2 244 Репутация
Автор 5 руководств
Команда
Cal Poly, Team 70-6, Forte Winter 2015 Участник Cal Poly, Team 70-6, Forte Winter 2015
CPSU-FORTE-W15S70G6
4 членов
Автор 16 руководств
6 Комментариев
hi where can i buy an antenna connector ?
i live in india.
ramumohan007 - Ответить
Google kar le
ravi raj -
I broke the actual ports that the antenna cables connect to on the mother board. Is thereally away to fix them or do I have to replace the whole logic/motherboard? I would like to keep my logic/motherboard because I don't want to lose all my text messages. What should I do?
shanonsmitt16 - Ответить
I also broke the connector component on the motherboard. It remains attached to the blue cable. Could this be re-soldered?
Leanahtan Eiddiwnid - Ответить
Is there a make shift way to put a extra antenna using one the two antenna ports above and to the left of the standard antenna cable. Without make any holes on the housing its self
Pedro A Sosa - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 14
За последние 30 дней: 24
За всё время: 23,318
