Samsung Galaxy Note 8.0 Speaker Replacement
Выберете то, что вам нужно
  1. Samsung Galaxy Note 8.0 Speaker Replacement, Back Cover: шаг 1, изображение 1 из 1
    • Remove the Samsung S-Pen stylus.
    • Remove the micro SD storage card.
  2. Samsung Galaxy Note 8.0 Speaker Replacement: шаг 2, изображение 1 из 1
    • Using the plastic opening tool, start where the S-pen was located and carefully pry up the corner.
  3. Samsung Galaxy Note 8.0 Speaker Replacement: шаг 3, изображение 1 из 1
    • Work your way around the entire device by carefully prying and sliding the plastic opening tool.
    • There are clips approximately 2cm apart. As you are removing the back cover you should hear the clips being dislocated from the tablet.
  4. Samsung Galaxy Note 8.0 Speaker Replacement, Battery: шаг 4, изображение 1 из 2 Samsung Galaxy Note 8.0 Speaker Replacement, Battery: шаг 4, изображение 2 из 2
    • Remove the 8 Phillips#00 3-mm screws holding the battery in place.
  5. Samsung Galaxy Note 8.0 Speaker Replacement: шаг 5, изображение 1 из 1
    • Lift the top left corner of the battery up by the black tab.
  6. Samsung Galaxy Note 8.0 Speaker Replacement: шаг 6, изображение 1 из 1
    • Gently grasp and lift up the white connector located at the bottom right corner of the battery. It is connected to the battery by two blue and two red wires.
    • Do not yank the connector by the wires. If it does not disconnect easily, slide a plastic opening tool between the white connector and the board to lift the connector away from the board.
  7. Samsung Galaxy Note 8.0 Speaker Replacement, Speakers: шаг 7, изображение 1 из 3 Samsung Galaxy Note 8.0 Speaker Replacement, Speakers: шаг 7, изображение 2 из 3 Samsung Galaxy Note 8.0 Speaker Replacement, Speakers: шаг 7, изображение 3 из 3
    • Gently pry up the connectors there is one per speaker
    • Do not yank the connector. If it does not disconnect easily use a plastic opening tool between the connector and the board to lift the connector away from the board.
  8. Samsung Galaxy Note 8.0 Speaker Replacement: шаг 8, изображение 1 из 2 Samsung Galaxy Note 8.0 Speaker Replacement: шаг 8, изображение 2 из 2
    • For each speaker remove the two 3-mm Phillips head screws using a Phillips #00 screwdriver.
  9. Samsung Galaxy Note 8.0 Speaker Replacement: шаг 9, изображение 1 из 2 Samsung Galaxy Note 8.0 Speaker Replacement: шаг 9, изображение 2 из 2
    • Remove the speakers from their housing.
    • If difficult use a plastic opening tool to pry up.
Заключение
4 участников успешно повторили данное руководство.
Joel
Участник с: 09/23/14
1 856 Репутация
Автор 6 руководств
Команда
USF Tampa, Team 12-2, Blackwell Fall 2014 Участник USF Tampa, Team 12-2, Blackwell Fall 2014
USFT-BLACKWELL-F14S12G2
4 членов
Автор 16 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 7
За всё время: 2,637
