Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
The phones motherboard is the hub of all activity on the phone. It is a very important component, and is essential for the phone to operate.
Запчасти
Детали не указаны.
  1. Power down your device and make sure that it is turned off.
    • Power down your device and make sure that it is turned off.
    • Place the phone with the screen facing down on a clean flat surface.
  2. Use your Supdger to remove the back cover of the phone using notch located in the top left corner of the phone. Remove battery by using your Supdger on the notch located directly underneath battery location. During the creation of this guide, we did not have access to a battery in our device.
    • Use your Supdger to remove the back cover of the phone using notch located in the top left corner of the phone.
    • Remove battery by using your Supdger on the notch located directly underneath battery location.
    • During the creation of this guide, we did not have access to a battery in our device.
  3. Remove the SIM Card from the SIM Card holder by gently sliding the SIM Card horizontally.
    • Remove the SIM Card from the SIM Card holder by gently sliding the SIM Card horizontally.
    • Remove the stylus from the stylus holder.
  4. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  5. Using a Phillips #000 Screwdriver, remove the fifteen 4mm screws that secure the rear chassis. Insert your spudger into the stylus socket and pry the midframe from the phone. Move the spudger around edge of phone, carefully prying the midframe from the phone until midframe is entirely separated.
    • Using a Phillips #000 Screwdriver, remove the fifteen 4mm screws that secure the rear chassis.
    • Insert your spudger into the stylus socket and pry the midframe from the phone.
    • Move the spudger around edge of phone, carefully prying the midframe from the phone until midframe is entirely separated.
  6. With the pointed end of your spudger, disconnect the two wires (pink and white) located near the bottom of the phone. Using pointed end of your dpudger, disconnect the finger print scanner cable- it is located directly above the pink and white cables.
    • With the pointed end of your spudger, disconnect the two wires (pink and white) located near the bottom of the phone.
    • Using pointed end of your dpudger, disconnect the finger print scanner cable- it is located directly above the pink and white cables.
  7. Using your Spudger's pointed end, pry off the following leads that connect these parts to the logic board in the top left hand corner: Front Facing Camera AMOLED Display Screen
    • Using your Spudger's pointed end, pry off the following leads that connect these parts to the logic board in the top left hand corner:
    • Front Facing Camera
    • AMOLED Display Screen
    • AMOLED Capacitive Screen
  8. At the top end, gently insert pointed end of spudger underneath the motherboard. Lift the motherboard up gently. Disconnect the cable connecting the daughter board. It is attached to the underside of the motherboard. Remove the motherboard from the device.
    • At the top end, gently insert pointed end of spudger underneath the motherboard.
    • Lift the motherboard up gently. Disconnect the cable connecting the daughter board. It is attached to the underside of the motherboard.
    • Remove the motherboard from the device.
Заключение
3 участников успешно повторили данное руководство.
Matt Clark
Участник с: 19.04.2018
145 Репутация
1 руководство автора
Команда
Cal Poly, Team S22-G6, Maness Spring 2018 Участник Cal Poly, Team S22-G6, Maness Spring 2018
CPSU-MANESS-S18S22G6
4 членов
Автор 10 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 9
За последние 30 дней: 47
За всё время: 2,337
