Samsung Galaxy Note Edge Rear Facing Camera Replacement
Выберете то, что вам нужно
  1. Samsung Galaxy Note Edge Rear Facing Camera Replacement, Battery: шаг 1, изображение 1 из 1
    • Power down your device and make sure that it is turned off.
    • Place the phone with the screen facing down on a clean flat surface.
  2. Samsung Galaxy Note Edge Rear Facing Camera Replacement: шаг 2, изображение 1 из 3 Samsung Galaxy Note Edge Rear Facing Camera Replacement: шаг 2, изображение 2 из 3 Samsung Galaxy Note Edge Rear Facing Camera Replacement: шаг 2, изображение 3 из 3
    • Use your Supdger to remove the back cover of the phone using notch located in the top left corner of the phone.
    • Remove battery by using your Supdger on the notch located directly underneath battery location.
    • During the creation of this guide, we did not have access to a battery in our device.
  3. Samsung Galaxy Note Edge Rear Facing Camera Replacement, Motherboard: шаг 3, изображение 1 из 1
    • Remove the SIM Card from the SIM Card holder by gently sliding the SIM Card horizontally.
    • Remove the stylus from the stylus holder.
  4. Samsung Galaxy Note Edge Rear Facing Camera Replacement: шаг 4, изображение 1 из 3 Samsung Galaxy Note Edge Rear Facing Camera Replacement: шаг 4, изображение 2 из 3 Samsung Galaxy Note Edge Rear Facing Camera Replacement: шаг 4, изображение 3 из 3
    • Using a Phillips #000 Screwdriver, remove the fifteen 4mm screws that secure the rear chassis.
    • Insert your spudger into the stylus socket and pry the midframe from the phone.
    • Move the spudger around edge of phone, carefully prying the midframe from the phone until midframe is entirely separated.
  5. Samsung Galaxy Note Edge Rear Facing Camera Replacement: шаг 5, изображение 1 из 2 Samsung Galaxy Note Edge Rear Facing Camera Replacement: шаг 5, изображение 2 из 2
    • With the pointed end of your spudger, disconnect the two wires (pink and white) located near the bottom of the phone.
    • Using pointed end of your dpudger, disconnect the finger print scanner cable- it is located directly above the pink and white cables.
  6. Samsung Galaxy Note Edge Rear Facing Camera Replacement: шаг 6, изображение 1 из 3 Samsung Galaxy Note Edge Rear Facing Camera Replacement: шаг 6, изображение 2 из 3 Samsung Galaxy Note Edge Rear Facing Camera Replacement: шаг 6, изображение 3 из 3
    • Using your Spudger's pointed end, pry off the following leads that connect these parts to the logic board in the top left hand corner:
    • Front Facing Camera
    • AMOLED Display Screen
    • AMOLED Capacitive Screen
  7. Samsung Galaxy Note Edge Rear Facing Camera Replacement: шаг 7, изображение 1 из 3 Samsung Galaxy Note Edge Rear Facing Camera Replacement: шаг 7, изображение 2 из 3 Samsung Galaxy Note Edge Rear Facing Camera Replacement: шаг 7, изображение 3 из 3
    • At the top end, gently insert pointed end of spudger underneath the motherboard.
    • Lift the motherboard up gently. Disconnect the cable connecting the daughter board. It is attached to the underside of the motherboard.
    • Remove the motherboard from the device.
  8. Samsung Galaxy Note Edge Rear Facing Camera Replacement, Rear Facing Camera: шаг 8, изображение 1 из 1
    • The rear facing camera will be attached to the motherboard.
    • Using the pointed end of spudger, disconnect cable located to the right of the camera.
    • Perform this step on a flat surface, as the camera will separate entirely once cable has been disconnected. Failure to do so will result in your camera falling down.
    • Remove the rear-facing camera from the device.
Заключение
To reassemble your device, follow steps in reverse order.
Nicholas Guillermo-Martinez
Участник с: 04/24/18
184 Репутация
Автор 2 руководств
Команда
Cal Poly, Team S22-G6, Maness Spring 2018 Участник Cal Poly, Team S22-G6, Maness Spring 2018
CPSU-MANESS-S18S22G6
4 членов
Автор 10 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 6
За всё время: 515
