Введение
Use this guide to replace a broken speaker in a Samsung Galaxy Note II.
  1. Grasp the end of the stylus and remove it from its slot in the midframe. Grasp the end of the stylus and remove it from its slot in the midframe.
    • Grasp the end of the stylus and remove it from its slot in the midframe.
  2. Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button. Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
  3. Lift the rear case by the corner nearest the divot and remove it from the phone. Lift the rear case by the corner nearest the divot and remove it from the phone. Lift the rear case by the corner nearest the divot and remove it from the phone.
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
  4. If you have an SD card inserted, use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click. After the click, release the card and it will pop out of its slot. Remove the microSD card.
    • If you have an SD card inserted, use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Remove the microSD card.
    • For reassembly, push the microSD card into the slot until it clicks in place.
  5. Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward. Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
    • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
  6. Remove the battery from the midframe.
    • Remove the battery from the midframe.
  7. iPhone Battery Fix Kits
    Only $29.99
    Buy Now
    Only $29.99
    Buy Now
  8. Remove the eleven 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
    • Remove the eleven 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
  9. Insert your plastic opening tool between the midframe and front panel assembly on the side of the phone. Slide the plastic opening tool down the seam. Slide the plastic opening tool down the seam.
    • Insert your plastic opening tool between the midframe and front panel assembly on the side of the phone.
    • Slide the plastic opening tool down the seam.
  10. Continue to run the plastic opening tool down the seam. Continue to run the plastic opening tool down the seam. Continue to run the plastic opening tool down the seam.
    • Continue to run the plastic opening tool down the seam.
  11. Carefully pry around the corner with a plastic opening tool. Carefully pry around the corner with a plastic opening tool.
    • Carefully pry around the corner with a plastic opening tool.
  12. Pry along the top of the phone with a plastic opening tool. Pry along the top of the phone with a plastic opening tool.
    • Pry along the top of the phone with a plastic opening tool.
  13. Push the plastic opening tool down to free the corner of the midframe from the display assembly. Push the plastic opening tool down to free the corner of the midframe from the display assembly.
    • Push the plastic opening tool down to free the corner of the midframe from the display assembly.
  14. Free the clips along the power button side of the phone. Lastly, free the two clips along the top and bottom edge of battery compartment.
    • Free the clips along the power button side of the phone.
    • Lastly, free the two clips along the top and bottom edge of battery compartment.
  15. Lift the display assembly out of the midframe. Lift the display assembly out of the midframe.
    • Lift the display assembly out of the midframe.
  16. Remove the 3 mm Phillips #00 screw from the speaker enclosure.
    • Remove the 3 mm Phillips #00 screw from the speaker enclosure.
  17. Remove the speaker enclosure.
    • Remove the speaker enclosure.
Заключение
9 участников успешно повторили данное руководство.
Sam Goldheart
Участник с: 18.10.2012
370 326 Репутация
Автор 538 руководств
Команда
iFixit Member of iFixit
Community
101 членов
Автор 8 660 руководств
Один комментарий
This is an awesome guide! Cheers Sam. I have never done any electrical fixes before so I was a phone fixing virgin. I bought both the tools and the speaker for £5.80 on ebay, followed your guide carefully and had no problems. It was an easy process. Thanks to the confidence I had in your guide I didn’t have to go and buy a new phone so you saved me the £180 I thought I was going to have to spend!
Cheers, Nick (UK)
Nick Village - Ответить
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 4
За 30 дней: 24
За всё время: 13,224
