Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Use this guide to replace a broken speaker in a Samsung Galaxy Note II.
Выберете то, что вам нужно
Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
Lift the rear case by the corner nearest the divot and remove it from the phone.
If you have an SD card inserted, use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
After the click, release the card and it will pop out of its slot.
Remove the microSD card.
Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
Remove the eleven 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
Insert your plastic opening tool between the midframe and front panel assembly on the side of the phone.
Slide the plastic opening tool down the seam.
Push the plastic opening tool down to free the corner of the midframe from the display assembly.
Free the clips along the power button side of the phone.
Lastly, free the two clips along the top and bottom edge of battery compartment.
Remove the 3 mm Phillips #00 screw from the speaker enclosure.
9 участников успешно повторили данное руководство.
Один комментарий
This is an awesome guide! Cheers Sam. I have never done any electrical fixes before so I was a phone fixing virgin. I bought both the tools and the speaker for £5.80 on ebay, followed your guide carefully and had no problems. It was an easy process. Thanks to the confidence I had in your guide I didn’t have to go and buy a new phone so you saved me the £180 I thought I was going to have to spend!
Cheers, Nick (UK)
