Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Disconnect the five base connectors from the motherboard by using the blue opening tool to carefully remove the connectors.
Using the blue opening tool, pry on the black tab at the base connector of ribbon cables until it is flipped up and moves with ease. Then, pull the ribbon cable from the base connectors of the motherboard.
Remove the power cable from the motherboard by prying slightly on both sides of the clip using tweezers.
Remove all three of the 3.0 mm screws using the Phillips #00 screwdriver.
Use the blue plastic opening tool to pry the speakers up from the clips that hold them in place.
Remove the motherboard using the blue opening tool while keeping any wires and connectors out of the way.
2 участников успешно повторили данное руководство.
