Введение
Use this guide to remove or replace the motherboard on your Samsung Galaxy Note10+.
Выберете то, что вам нужно
Insert a SIM eject tool, bit, or a straightened paper clip into the small hole on the SIM card tray on the top edge of the phone.
Press firmly to eject the tray.
Remove the SIM card tray.
Prepare an iOpener and apply it to the left edge of the rear cover for one minute.
Apply a suction cup to the heated edge of the rear cover, as close to the edge as possible.
Pull up on the suction cup with strong, steady force to create a gap between the rear cover and the frame.
Insert the point of an opening pick into the gap.
Slide the opening pick along the left edge towards the bottom left corner to slice the adhesive.
Leave the pick inserted in the bottom left corner to prevent the adhesive from re-sealing.
Repeat the previous heating and cutting procedure for the remaining three sides of the phone.
Leave an opening pick on each side as you continue to the next to prevent the adhesive from resealing.
Use a Phillips screwdriver to remove the five 4 mm screws securing the wireless charging coil.
Use a pair of tweezers to lift up and flip back the metal shield covering the battery connector.
While holding the metal shield up and out of the way, use the pointed end of a spudger to pry up the battery connector to disconnect it.
Use the pointed end of a spudger to disconnect the wireless charging coil connector from the motherboard.
Tilt the metal shielding up so you can grip it with your fingers.
Peel the wireless charging coil up and away from the device.
Remove the wireless charging coil.
Use a Phillips screwdriver to remove the five 4 mm screws securing the loudspeaker.
Use the pointed end of a spudger to disconnect the main interconnect cable from the motherboard.
Disconnect the secondary interconnect cable from the motherboard.
Use the pointed end of a spudger to disconnect the main interconnect cable from the daughterboard.
Disconnect the secondary interconnect cable from the daughterboard.
Use a Phillips screwdriver to remove the four 4 mm screws securing the top plastic cover.
Use the pointed end of a spudger to disconnect the touch layer connector from the motherboard.
Disconnect the side button connector from the motherboard.
Use the pointed end of a spudger to disconnect the S-Pen charging coil connector from the motherboard.
Use the pointed end of a spudger to disconnect the display cable from the motherboard.
Use the pointed end of a spudger to pry up the motherboard enough to grip it with your fingers.
Remove the motherboard.
6 участников успешно повторили данное руководство.
3 Комментариев
Hi can i replace motherboard from Galaxy Note 10 Plus N975U 256GB with Galaxy Note 10 Plus N975U1 512GB? Will all connectors match?
Hi ,
Can i swap motherboard note 10 plus 256 gb to note 10 plus 5g 512 gb bcoz note 10 plus has no 5g connection so
Samsung galaxy note10 plus 5g madarboard n976n
