Введение
Use this guide to remove or replace the rear camera assembly on your Samsung Galaxy Note20 Ultra.
The rear camera assembly consists of the ultra wide camera, the wide-angle camera, and the telephoto camera.
For your safety, discharge the battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Выберете то, что вам нужно
Insert a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole on the top edge of the phone.
Press firmly to eject the tray.
Remove the SIM card tray.
Heat an iOpener and apply it to the left side of the rear cover for one minute.
Apply a suction cup to the heated edge of the rear cover, as close to the edge as possible.
Pull up on the suction cup with strong, steady force to create a gap between the rear cover and the frame.
Insert an opening pick into the gap.
Slide the opening pick along the left edge towards the bottom left corner to cut through the adhesive.
Leave the pick inserted in the bottom left corner to prevent the adhesive from re-sealing.
Repeat the process of heating and cutting the adhesive along the three remaining sides of the rear cover.
As you proceed, leave an opening pick in each corner to prevent the adhesive from re-sealing.
Slide an opening pick back and forth around the entire perimeter of the phone to release any missed adhesive. Reheat any stubborn adhesive.
Use the pointed end of a spudger to pry up and disconnect the wireless charging coil press connector.
Use the pointed end of a spudger to pry up and disconnect the white press connector located in the bottom right of the motherboard shield.
Use a Phillips screwdriver to remove the six 4.0 mm screws securing the motherboard shield.
Use a pair of tweezers to lift up the motherboard shield.
Use your fingers to grip the motherboard shield.
Use the pointed end of a spudger to pry up the battery press connector to safely disconnect the battery before continuing repairs.
Use the pointed end of a spudger to pry up the laser AF sensor press connector.
Use a Phillips screwdriver to remove the four 4.0 mm screws securing the earpiece speaker.
Insert the pointed end of a spudger into the hole marked by a small triangle on the right side of the earpiece speaker.
Use the spudger to pry up and loosen the earpiece speaker from the frame.
Use the pointed end of a spudger to disconnect the front-facing camera cable from the motherboard.
Use the pointed end of a spudger to disconnect the display cable from the motherboard.
Use the pointed end of a spudger to disconnect the main interconnect cable from the motherboard.
Use the pointed end of a spudger to disconnect the secondary interconnect cable from the motherboard.
Use the pointed end of a spudger to disconnect the touch layer cable from the motherboard.
Use the pointed end of a spudger to disconnect the green press connector from the motherboard.
Use the pointed end of a spudger to disconnect the S-Pen press connector from the motherboard.
Use a Phillips screwdriver to remove the two 4.0 mm screws securing the motherboard to the frame.
Insert the flat end of a spudger under the bottom edge of the motherboard.
Pry up to loosen the motherboard from the frame.
Secondary interconnect cable
Battery cable
Main interconnect cable
Display cable
S-Pen cable
Touch layer cable and green press connector
Front-facing camera cable
Use the pointed end of a spudger to disconnect the ultra wide camera from the motherboard.
Use the pointed end of a spudger to disconnect the telephoto camera from the motherboard.
Use the pointed end of a spudger to disconnect the wide-angle camera from the motherboard.
Bend the ultra wide camera ribbon cable away from the motherboard so that the rear camera assembly can be removed.
Remove the rear camera assembly from the motherboard.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Samsung Galaxy Note20 Ultra Answers community for help.
3 участников успешно повторили данное руководство.
