Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
Samsung Galaxy Note 5 LCD screen replacement, USB board replacement and Home button flex replacement share the most same and complicated steps, so bring them together.
Video Overview
  1. Remove SIM card tray and S pen. Remove SIM card tray and S pen.
    • Remove SIM card tray and S pen.
  2. Remove back cover. Remove back cover. Remove back cover.
    • Remove back cover.
  3. Remove middle housing. Remove middle housing. Remove middle housing.
    • Remove middle housing.
  4. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  5. Remove battery. Remove battery. Remove battery.
    • Remove battery.
  6. Release connectors on the motherboard. Release connectors on the motherboard. Release connectors on the motherboard.
    • Release connectors on the motherboard.
  7. Release USB board connector on the back and remove the motherboard. Release USB board connector on the back and remove the motherboard. Release USB board connector on the back and remove the motherboard.
    • Release USB board connector on the back and remove the motherboard.
  8. Remove LCD screen. It's really difficult, see more details on Samsung Galaxy Note 5 teardown. Remove LCD screen. It's really difficult, see more details on Samsung Galaxy Note 5 teardown. Remove LCD screen. It's really difficult, see more details on Samsung Galaxy Note 5 teardown.
  9. Remove USB board. If you replace USB board only, please be careful with the LCD screen very much. Once a defect, the screen will be cracked or broken. Remove USB board. If you replace USB board only, please be careful with the LCD screen very much. Once a defect, the screen will be cracked or broken. Remove USB board. If you replace USB board only, please be careful with the LCD screen very much. Once a defect, the screen will be cracked or broken.
    • Remove USB board. If you replace USB board only, please be careful with the LCD screen very much. Once a defect, the screen will be cracked or broken.
  10. Push the button out from slot as the direction of mark. And then release the adhesive and remove button flex. The same tips: Be careful with the LCD screen! The same tips: Be careful with the LCD screen!
    • Push the button out from slot as the direction of mark. And then release the adhesive and remove button flex.
    • The same tips: Be careful with the LCD screen!
Заключение
72 участников успешно повторили данное руководство.
Sophia
Участник с: 25.03.2014
42 490 Репутация
Автор 62 руководств
Комментариев: 30
hola que debo hacer si en la pantalla amoled de mi galaxy note 5 se visualiza una mancha morada y al medio negro que se esta expandiendo por toda la pantalla y al colocarlo contra la luz se visualiza internamente una rajadura lo cual no me permita utilizar correctamente el teclado para escribir mensajes.
jorge - Ответить
me paso exactamente lo mismo...
solucionaste tu problema?
eselemichrisvega25 -
Cambiarla, esta internamente dañada.
msantanamontero - Ответить
Do I have o replace the lcd screen if my front screen has black marks
platinummom1 - Ответить
Lol that question was answered previously in Spanish (its just funny to me), but yes, it has internal damage, change the screen.
ninoabigail96 -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 28
За последние 30 дней: 122
За всё время: 148,136
