Samsung Galaxy Note5 Volume Button Replacement
Выберете то, что вам нужно
  1. Samsung Galaxy Note5 Volume Button Replacement, SIM Card Tray: шаг 1, изображение 1 из 1
    • Insert a SIM Ejector Tool into the small hole on the left side of the top edge of the device.
    • Press down until the SIM Card Tray begins to protrude out of the device.
  2. Samsung Galaxy Note5 Volume Button Replacement: шаг 2, изображение 1 из 1
    • Remove the SIM Card Tray from the slot.
  3. Samsung Galaxy Note5 Volume Button Replacement, Power Button: шаг 3, изображение 1 из 1
    • Heat the back of the device with a heat gun for 2 minutes
  4. Samsung Galaxy Note5 Volume Button Replacement: шаг 4, изображение 1 из 1
    • Once the device is heated, place a suction cup near the bottom of the back of the device Make sure it is placed on the flat part of the glass
    • Be careful holding the device after heating the back, it may burn!
    • Gently pull upwards on the suction cup to separate the rear glass from the body of the phone.
    • While pulling upwards, insert a pick under the rear glass
  5. Samsung Galaxy Note5 Volume Button Replacement: шаг 5, изображение 1 из 1
    • Keeping the pick under the rear glass, move the pick along the bottom edge of the device to cut the adhesive.
  6. Samsung Galaxy Note5 Volume Button Replacement: шаг 6, изображение 1 из 1
    • Repeat the previous heating and cutting procedure for the remaining three sides of the phone.
    • Leave a pick on each side as you continue to the next to prevent the adhesive from resealing.
  7. Samsung Galaxy Note5 Volume Button Replacement: шаг 7, изображение 1 из 1
    • Once all adhesive has been cut, gently lift up the rear glass to remove it.
  8. Samsung Galaxy Note5 Volume Button Replacement: шаг 8, изображение 1 из 1
    • Remove the S-Pen from the bottom of the device
  9. Samsung Galaxy Note5 Volume Button Replacement: шаг 9, изображение 1 из 2 Samsung Galaxy Note5 Volume Button Replacement: шаг 9, изображение 2 из 2
    • Remove 20 5mm screws with a Phillips #1 Screwdriver.
  10. Samsung Galaxy Note5 Volume Button Replacement: шаг 10, изображение 1 из 2 Samsung Galaxy Note5 Volume Button Replacement: шаг 10, изображение 2 из 2
    • Grip the back of the device and press down on the white square to remove the middle housing.
  11. Samsung Galaxy Note5 Volume Button Replacement: шаг 11, изображение 1 из 2 Samsung Galaxy Note5 Volume Button Replacement: шаг 11, изображение 2 из 2
    • Loosen the power button flex adhesive by holding it with the tweezers.
    • With the tweezers, pry up and remove the power button flex
  12. Samsung Galaxy Note5 Volume Button Replacement: шаг 12, изображение 1 из 1
    • Push out the power button with the tip of the tweezers.
  13. Samsung Galaxy Note5 Volume Button Replacement, Volume Button: шаг 13, изображение 1 из 2 Samsung Galaxy Note5 Volume Button Replacement, Volume Button: шаг 13, изображение 2 из 2
    • Loosen the volume flex adhesive.
    • Pry up and remove the volume button flex.
  14. Samsung Galaxy Note5 Volume Button Replacement: шаг 14, изображение 1 из 1
    • Push out the volume button and remove it from the device.
Заключение
2 участников успешно повторили данное руководство.
Bernice Nunez
Участник с: 04/19/18
340 Репутация
Автор 2 руководств
Команда
Cal Poly, Team S25-G17, Maness Spring 2018 Участник Cal Poly, Team S25-G17, Maness Spring 2018
CPSU-MANESS-S18S25G17
4 членов
Автор 5 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 8
За последние 30 дней: 19
За всё время: 1,238
