Samsung Galaxy Note8 Battery Replacement
Выберете то, что вам нужно
  1. Samsung Galaxy Note8 Battery Replacement, Back Cover: шаг 1, изображение 1 из 1
    • Switch off your phone.
    • Prepare an iOpener for softening the adhesive on the back of the Note8.
    • Apply the iOpener on the back of the Note8 along the side with the power button.
  2. Samsung Galaxy Note8 Battery Replacement: шаг 2, изображение 1 из 3 Samsung Galaxy Note8 Battery Replacement: шаг 2, изображение 2 из 3 Samsung Galaxy Note8 Battery Replacement: шаг 2, изображение 3 из 3
    • Use a suction handle to lift the back cover and create an opening pick to get in the gap.
    • Since the back cover is also slightly curved at the edges you want to insert the opening pick at a lower angle from underneath.
    • Start at the middle of the side and cut the adhesive while pulling up with the suction handle.
    • Be careful not to lever the opening pick too much to avoid breaking the back cover. Rather pull with the suction handle and use the pick for cutting the adhesive.
    • Move the pick towards the bottom corner and leave it there to keep the adhesive from resealing to the case.
    • Use another pick and move it to the top corner.
    • If it's getting harder to move the pick you might need to reheat the iOpener and apply it to the back cover again.
  3. Samsung Galaxy Note8 Battery Replacement: шаг 3, изображение 1 из 3 Samsung Galaxy Note8 Battery Replacement: шаг 3, изображение 2 из 3 Samsung Galaxy Note8 Battery Replacement: шаг 3, изображение 3 из 3
    • Again take another opening pick and carefully move it around the corner and along the top edge.
    • Reheat with an iOpener if necessary.
    • Leave the pick at the top right corner to keep the adhesive from resealing.
  4. Samsung Galaxy Note8 Battery Replacement: шаг 4, изображение 1 из 3 Samsung Galaxy Note8 Battery Replacement: шаг 4, изображение 2 из 3 Samsung Galaxy Note8 Battery Replacement: шаг 4, изображение 3 из 3
    • Rotate the device and start to separate the adhesive at the bottom with another opening pick.
    • Leave the pick at the bottom right corner to keep the adhesive from resealing.
  5. Samsung Galaxy Note8 Battery Replacement: шаг 5, изображение 1 из 3 Samsung Galaxy Note8 Battery Replacement: шаг 5, изображение 2 из 3 Samsung Galaxy Note8 Battery Replacement: шаг 5, изображение 3 из 3
    • When the adhesive has been separated on all three sides properly you will be able to slowly lift the back cover.
    • Don't force it open. Use an iOpener to again soften the adhesive if the back cover won't come off or starts to bend.
    • Pay attention to the fingerprint sensor connector when flipping the back cover open. You might need to disconnect it as described in the next step.
  6. Samsung Galaxy Note8 Battery Replacement: шаг 6, изображение 1 из 1
    • Use a pair of tweezers to disconnect the fingerprint sensor.
    • The connector might already have come off when flipping the back cover open.
  7. Samsung Galaxy Note8 Battery Replacement: шаг 7, изображение 1 из 1
    • Remove the back cover.
    • To prepare for the reassembly remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
  8. Samsung Galaxy Note8 Battery Replacement, NFC Antenna and Charging Coil Assembly: шаг 8, изображение 1 из 1
    • Remove the ten Phillips #00 screws.
  9. Samsung Galaxy Note8 Battery Replacement: шаг 9, изображение 1 из 2 Samsung Galaxy Note8 Battery Replacement: шаг 9, изображение 2 из 2
    • Use an opening pick at the top edge to get between the NFC antenna and charging coil assembly and the case.
    • Lever the top of the assembly out of the case.
  10. Samsung Galaxy Note8 Battery Replacement: шаг 10, изображение 1 из 1
    • Carefully pull up the complete charging coil and NFC antenna assembly.
    • The bottom left part of the assembly is slightly glued down to the frame.
  11. Samsung Galaxy Note8 Battery Replacement, Battery Disconnect: шаг 11, изображение 1 из 1
    • Use the flat end of a spudger to disconnect the battery connector.
  12. Samsung Galaxy Note8 Battery Replacement, Battery: шаг 12, изображение 1 из 1
    • Prepare an iOpener and apply it to the display for at least two minutes to loosen the adhesive beneath the battery. Reheat and reapply the iOpener as needed.
    • Alternatively or when the battery is blown up, you can apply some isopropyl alcohol under each corner of the battery and allow it to penetrate for several minutes to help weaken the adhesive.
  13. Samsung Galaxy Note8 Battery Replacement: шаг 13, изображение 1 из 2 Samsung Galaxy Note8 Battery Replacement: шаг 13, изображение 2 из 2
    • Use the flat end of a spudger to pry up the battery from the top right corner.
    • You will be prying against the case directly above the mainboard. Pry carefully to avoid damaging any close components.
    • You may need to reheat and reapply the iOpener repeatedly to further soften the adhesive. The adhesive is tough and it may take a few tries to get the spudger started under the battery.
    • Use the spudger to pry up the battery until you can insert an opening pick to prevent the adhesive from resealing.
    • Try your best not to deform the battery during this process. Soft-shell lithium-ion batteries can leak dangerous chemicals, catch fire, or even explode if damaged. Do not use excessive force or pry at the battery with metal tools.
  14. Samsung Galaxy Note8 Battery Replacement: шаг 14, изображение 1 из 3 Samsung Galaxy Note8 Battery Replacement: шаг 14, изображение 2 из 3 Samsung Galaxy Note8 Battery Replacement: шаг 14, изображение 3 из 3
    • Use the flat end of the spudger to pry up the top left corner of the battery where the flex cable is located.
    • Slide the spudger along the side of the battery to break apart remaining adhesive.
    • When prying keep to the areas marked orange. Avoid the red area in the middle which is the back of the display.
  15. Samsung Galaxy Note8 Battery Replacement: шаг 15, изображение 1 из 1
    • Lift the battery out of the case.
    • Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
    • Remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
    • Follow this guide to install battery adhesive.
    • Follow this guide to install custom-cut adhesives.
Заключение
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the phone at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place for 5-10 seconds.
To reassemble your device, follow these instructions in reverse order, replacing the adhesive where needed.
If possible, turn on your phone and test your repair before closing and sealing up the phone.
For best results, when your repair is complete, calibrate your newly-installed battery.
68 участников успешно повторили данное руководство.
Tobias Isakeit
Участник с: 03/31/14
117 588 Репутация
Автор 188 руководств
Команда
Master Techs Участник Master Techs
Community
322 членов
Автор 2 528 руководств
10 Комментариев
Awesome fix. Do you have anything for the front glass replacements by chance? I want to do both at the same time
Rick Moore - Ответить
For those wondering how to apply the replacement adhesive, there is a video on the iFixit YouTube channel about installing adhesive on Samsung devices. Its a bit generic, but it points you in the right direction.
Christopher Zibbell - Ответить
Hi Christopher,
I’ve edited the last step to include some adhesive guides! Hope that helps!
Arthur Shi -
Thanks!! Very good detail. I was able to get the back cover off and replace the battery - the phone is working like a champ!
Phil Brooks - Ответить
Would it be possible to augment the mAh? instead of 3300 mAh giving a little bit more power?
William Houli - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 28
За последние 7 дней: 235
За последние 30 дней: 927
За всё время: 98,155
