Введение
Use this guide to replace a broken NFC antenna and charging coil assembly in the Samsung Galaxy Note8.
Before disassembling your phone, discharge the battery below 25%. The battery can catch fire and/or explode if accidentally punctured, but the chances of that happening are much lower if discharged.
If your battery is swollen, do not heat your phone. If needed, you can use a dropper or syringe to inject isopropyl alcohol (90+%) around the edges of the back cover to weaken the adhesive. Swollen batteries can be very dangerous, so wear eye protection and exercise due caution, or take it to a professional if you're not sure how to proceed.
Opening the Samsung Galaxy Note8 will damage the waterproof sealing on the device. If you do not replace the adhesive seals, your phone will function normally, but will loose water-protection.
This guide involves removing the rear glass cover, you will need replacement adhesive to reattach the back cover to the phone.
Выберете то, что вам нужно
Switch off your phone.
Prepare an iOpener for softening the adhesive on the back of the Note8.
Apply the iOpener on the back of the Note8 along the side with the power button.
Use a suction handle to lift the back cover and create an opening pick to get in the gap.
Start at the middle of the side and cut the adhesive while pulling up with the suction handle.
Move the pick towards the bottom corner and leave it there to keep the adhesive from resealing to the case.
Use another pick and move it to the top corner.
Again take another opening pick and carefully move it around the corner and along the top edge.
Reheat with an iOpener if necessary.
Leave the pick at the top right corner to keep the adhesive from resealing.
Rotate the device and start to separate the adhesive at the bottom with another opening pick.
Leave the pick at the bottom right corner to keep the adhesive from resealing.
When the adhesive has been separated on all three sides properly you will be able to slowly lift the back cover.
Pay attention to the fingerprint sensor connector when flipping the back cover open. You might need to disconnect it as described in the next step.
Use an opening pick at the top edge to get between the NFC antenna and charging coil assembly and the case.
Lever the top of the assembly out of the case.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where it is necessary.
8 участников успешно повторили данное руководство.
