Введение
Follow this guide to replace the back cover of your Samsung Galaxy Note9.
Выберете то, что вам нужно
Power off your phone before beginning disassembly.
Use a hairdryer, a heatgun, or prepare an iOpener and apply it to the right edge of the back of the phone for about a minute to soften the adhesive underneath.
Apply a suction handle to the back cover.
Lift with a suction handle to create a gap between the back cover and the frame of the phone.
Insert an opening pick into the gap.
Note that there is more adhesive along the top edge and around the camera bezel than around the rest of the phone.
Cut carefully around the left edge near the fingerprint sensor or you risk damaging the ribbon cable inside.
Starting from the center, cut the adhesive up and down the right side with an opening pick.
Leave an opening pick in the upper-right corner.
Use another opening pick to cut the adhesive around the bottom-right corner.
Leave that opening pick in the phone.
Use a heat gun or hair dryer or apply a heated iOpener to the left side of the rear panel for at three minutes to soften the adhesive underneath.
Insert an opening pick into the lower-left corner of the rear panel.
Using another opening pick, cut the adhesive along the left edge of the rear panel.
Using the inserted opening pick, carefully cut the adhesive around the upper-left corner of the rear panel.
Finally, cut the last of the adhesive along the top of the phone.
Separate the right side of the rear cover first.
Tilt the cover up along the left edge to expose the fingerprint sensor ribbon cable.
Use the tip of a spudger to pry the fingerprint sensor ribbon cable up and out of its socket.
Remove the back cover.
Use tweezers to peel away any remaining adhesive from the phone's chassis. Then clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth to prep the surface for the new adhesive. You don't have to clear out adhesive down to the plastic but larger pieces should be removed.
Turn on your phone and test your repair before installing new adhesive and resealing the phone.
Carefully apply the new adhesive to the back cover, then line up one edge of the glass against the phone chassis and firmly press the glass into the phone.
Use a heat gun, hair dryer or apply a heated iOpener on the outside of the fingerprint sensor to soften the adhesive underneath. Heat it until it's slightly too hot to touch, as the adhesive is soft and resists tearing.
Insert an opening pick under the back of the fingerprint sensor.
Twist the opening pick to separate the fingerprint sensor from the back cover.
Remove the fingerprint sensor.
Use tweezers to peel off as much adhesive as you can. Then clean off the remaining adhesive with 90% isopropyl alcohol and a lint-free cloth.
18 участников успешно повторили данное руководство.
3 Комментариев
Thank you for the Guide
Excellent. Thank you
So where do I get the back panel replacement part?
