Samsung Galaxy Note9 Front-Facing Camera Replacement
Выберете то, что вам нужно
    1. Samsung Galaxy Note9 Front-Facing Camera Replacement, Apply a heated iOpener: шаг 1, изображение 1 из 1
      • Power off your phone before beginning disassembly.
      • Use a hairdryer, a heatgun, or prepare an iOpener and apply it to the right edge of the back of the phone for about a minute to soften the adhesive underneath.
      Спросите у FixBot
      Добавить комментарий
    2. Samsung Galaxy Note9 Front-Facing Camera Replacement, Insert an opening pick: шаг 2, изображение 1 из 3 Samsung Galaxy Note9 Front-Facing Camera Replacement, Insert an opening pick: шаг 2, изображение 2 из 3 Samsung Galaxy Note9 Front-Facing Camera Replacement, Insert an opening pick: шаг 2, изображение 3 из 3
      • Apply a suction handle to the back cover.
      • Lift with a suction handle to create a gap between the back cover and the frame of the phone.
      • Insert an opening pick into the gap.
      • If the glass is badly cracked, cover it in packing tape to create a surface for the suction cup to adhere to.
      • If the adhesive won't budge, apply more heat, not excessive force. Too much force could break the glass.
      Спросите у FixBot
    3. Samsung Galaxy Note9 Front-Facing Camera Replacement, Cut through the adhesive: шаг 3, изображение 1 из 1
      • Note that there is more adhesive along the top edge and around the camera bezel than around the rest of the phone.
      • Cut carefully around the left edge near the fingerprint sensor or you risk damaging the ribbon cable inside.
      • If, at any point, the adhesive feels stubborn, apply more heat—not more force.
      Спросите у FixBot
    4. Samsung Galaxy Note9 Front-Facing Camera Replacement, Slide the opening pick: шаг 4, изображение 1 из 3 Samsung Galaxy Note9 Front-Facing Camera Replacement, Slide the opening pick: шаг 4, изображение 2 из 3 Samsung Galaxy Note9 Front-Facing Camera Replacement, Slide the opening pick: шаг 4, изображение 3 из 3
      • Starting from the center, cut the adhesive up and down the right side with an opening pick.
      • Do not insert the pick more than halfway into the phone when cutting near the fingerprint sensor or cameras, or you risk damaging internal components.
      Спросите у FixBot
    5. Samsung Galaxy Note9 Front-Facing Camera Replacement: шаг 5, изображение 1 из 3 Samsung Galaxy Note9 Front-Facing Camera Replacement: шаг 5, изображение 2 из 3 Samsung Galaxy Note9 Front-Facing Camera Replacement: шаг 5, изображение 3 из 3
      • Be careful near the corner, as the glass is very weak. Apply more heat at any time if the adhesive becomes stuck.
      • Leave an opening pick in the upper-right corner.
      • Use another opening pick to cut the adhesive around the bottom-right corner.
      • Leave that opening pick in the phone.
      Спросите у FixBot
    6. Samsung Galaxy Note9 Front-Facing Camera Replacement: шаг 6, изображение 1 из 1
      • Use a heat gun or hair dryer or apply a heated iOpener to the left side of the rear panel for at three minutes to soften the adhesive underneath.
      Спросите у FixBot
    7. Samsung Galaxy Note9 Front-Facing Camera Replacement: шаг 7, изображение 1 из 3 Samsung Galaxy Note9 Front-Facing Camera Replacement: шаг 7, изображение 2 из 3 Samsung Galaxy Note9 Front-Facing Camera Replacement: шаг 7, изображение 3 из 3
      • Be careful near the corners, as the glass is weakest there.
      • Insert an opening pick into the lower-left corner of the rear panel.
      • Using another opening pick, cut the adhesive along the left edge of the rear panel.
      • Don't insert an opening pick in more than halfway on the left edge near the fingerprint sensor or you may damage the ribbon cable inside.
      • It is fine if opening picks fall out as the back cover becomes separated.
      Спросите у FixBot
    8. Samsung Galaxy Note9 Front-Facing Camera Replacement: шаг 8, изображение 1 из 3 Samsung Galaxy Note9 Front-Facing Camera Replacement: шаг 8, изображение 2 из 3 Samsung Galaxy Note9 Front-Facing Camera Replacement: шаг 8, изображение 3 из 3
      • Using the inserted opening pick, carefully cut the adhesive around the upper-left corner of the rear panel.
      • Finally, cut the last of the adhesive along the top of the phone.
      • Use an iOpener, hair dryer, or heat gun to apply more heat as needed where you are cutting the adhesive.
      Спросите у FixBot
    9. Samsung Galaxy Note9 Front-Facing Camera Replacement: шаг 9, изображение 1 из 2 Samsung Galaxy Note9 Front-Facing Camera Replacement: шаг 9, изображение 2 из 2
      • Separate the right side of the rear cover first.
      • Tilt the cover up along the left edge to expose the fingerprint sensor ribbon cable.
      • Do not pull out the fingerprint sensor ribbon cable yet.
      • The fingerprint sensor cover might stay attached to the midframe.
      Спросите у FixBot
    10. Samsung Galaxy Note9 Front-Facing Camera Replacement, Disconnect the fingerprint sensor: шаг 10, изображение 1 из 2 Samsung Galaxy Note9 Front-Facing Camera Replacement, Disconnect the fingerprint sensor: шаг 10, изображение 2 из 2
      • Use the tip of a spudger to pry the fingerprint sensor ribbon cable up and out of its socket.
      Спросите у FixBot
    11. Samsung Galaxy Note9 Front-Facing Camera Replacement: шаг 11, изображение 1 из 1
      Инструмент, используемый на этом этапе:
      • Remove the back cover.
      • To re-install the back cover:
      • Use tweezers to peel away any remaining adhesive from the phone's chassis. Then clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth to prep the surface for the new adhesive. You don't have to clear out adhesive down to the plastic but larger pieces should be removed.
      • Turn on your phone and test your repair before installing new adhesive and resealing the phone.
      • Carefully apply the new adhesive to the back cover, then line up one edge of the glass against the phone chassis and firmly press the glass into the phone.
      Спросите у FixBot
    1. Внимание: шаги 12-15 взяты из руководства, помеченного как незавершенное.
      Samsung Galaxy Note9 Front-Facing Camera Replacement, Remove the upper midframe: шаг 12, изображение 1 из 2 Samsung Galaxy Note9 Front-Facing Camera Replacement, Remove the upper midframe: шаг 12, изображение 2 из 2
      • Use a Phillips screwdriver to remove the nine 4 mm screws securing the upper midframe.
      Спросите у FixBot
    2. Samsung Galaxy Note9 Front-Facing Camera Replacement: шаг 13, изображение 1 из 2 Samsung Galaxy Note9 Front-Facing Camera Replacement: шаг 13, изображение 2 из 2
      • Insert the tip of a spudger into the upper-left corner of the upper midframe.
      • Pry the upper midframe out of the phone.
      • The upper midframe snaps into and out of place.
      Спросите у FixBot
    3. Samsung Galaxy Note9 Front-Facing Camera Replacement: шаг 14, изображение 1 из 3 Samsung Galaxy Note9 Front-Facing Camera Replacement: шаг 14, изображение 2 из 3 Samsung Galaxy Note9 Front-Facing Camera Replacement: шаг 14, изображение 3 из 3
      • Peel the wireless charging coil off the battery starting with the left side.
      • The adhesive is weak but you can use an opening pick to cut it if necessary.
      • During reassembly start by snapping the midframe into place first before adhering the wireless charging coil.
      Спросите у FixBot
    4. Samsung Galaxy Note9 Front-Facing Camera Replacement, Disconnect the battery: шаг 15, изображение 1 из 2 Samsung Galaxy Note9 Front-Facing Camera Replacement, Disconnect the battery: шаг 15, изображение 2 из 2
      • Use the tip of a spudger to disconnect the orange ribbon cable connecting the battery to the motherboard.
      Спросите у FixBot
    1. Samsung Galaxy Note9 Front-Facing Camera Replacement, Remove the front camera: шаг 16, изображение 1 из 3 Samsung Galaxy Note9 Front-Facing Camera Replacement, Remove the front camera: шаг 16, изображение 2 из 3 Samsung Galaxy Note9 Front-Facing Camera Replacement, Remove the front camera: шаг 16, изображение 3 из 3
      • Use the tip of a spudger to pry the front camera connector straight up and out of its socket.
      • Use tweezers to remove the front camera.
      Спросите у FixBot
Заключение
3 человек успешно провели ремонт по этому руководству.
Sam Omiotek
Участник с: 02/25/19
100 304 Репутация
Автор 289 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 13
За последние 30 дней: 56
За всё время: 2,000
