Введение
Follow this guide to replace the rear camera of a Samsung Galaxy Note9.
Выберете то, что вам нужно
Insert a SIM card eject tool straight into the hole in the SIM card tray.
Press to eject the SIM card tray.
Power off your phone before beginning disassembly.
Use a hairdryer, a heatgun, or prepare an iOpener and apply it to the right edge of the back of the phone for about a minute to soften the adhesive underneath.
Apply a suction handle to the back cover.
Lift with a suction handle to create a gap between the back cover and the frame of the phone.
Insert an opening pick into the gap.
Note that there is more adhesive along the top edge and around the camera bezel than around the rest of the phone.
Cut carefully around the left edge near the fingerprint sensor or you risk damaging the ribbon cable inside.
Starting from the center, cut the adhesive up and down the right side with an opening pick.
Leave an opening pick in the upper-right corner.
Use another opening pick to cut the adhesive around the bottom-right corner.
Leave that opening pick in the phone.
Use a heat gun or hair dryer or apply a heated iOpener to the left side of the rear panel for at three minutes to soften the adhesive underneath.
Insert an opening pick into the lower-left corner of the rear panel.
Using another opening pick, cut the adhesive along the left edge of the rear panel.
Using the inserted opening pick, carefully cut the adhesive around the upper-left corner of the rear panel.
Finally, cut the last of the adhesive along the top of the phone.
Separate the right side of the rear cover first.
Tilt the cover up along the left edge to expose the fingerprint sensor ribbon cable.
Use the tip of a spudger to pry the fingerprint sensor ribbon cable up and out of its socket.
Remove the back cover.
Use tweezers to peel away any remaining adhesive from the phone's chassis. Then clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth to prep the surface for the new adhesive. You don't have to clear out adhesive down to the plastic but larger pieces should be removed.
Turn on your phone and test your repair before installing new adhesive and resealing the phone.
Carefully apply the new adhesive to the back cover, then line up one edge of the glass against the phone chassis and firmly press the glass into the phone.
Шаг 14 Remove the upper midframe
Careful: steps 14-17 are sourced from a guide that's marked as in-progress.
Use a Phillips screwdriver to remove the nine 4 mm screws securing the upper midframe.
Insert the tip of a spudger into the upper-left corner of the upper midframe.
Pry the upper midframe out of the phone.
Use the tip of a spudger to disconnect the orange ribbon cable connecting the battery to the motherboard.
Remove the nine 4 mm Phillips screws from the plastic cover next to the battery.
Insert the tip of a spudger into the top of the lower midframe.
Pry the lower midframe out from the phone.
Remove the lower midframe.
Use the tip of a spudger to pry the front camera connector straight up and out of its socket.
Use tweezers to remove the front camera.
Use the tip of a spudger to disconnect the iris scanner from the motherboard.
Use tweezers to remove the iris scanner.
Use the flat end of a spudger to pry the front sensor connector out of its socket.
Use the flat end of a spudger to disconnect the display cable from the motherboard.
Use the flat end of a spudger to disconnect the touchscreen cable from the motherboard.
Use the flat end of a spudger to disconnect the charging assembly from the motherboard.
Use a spudger to gently lift the motherbord from the upper-left corner.
Carefully remove the motherboard.
Use the tip of a spudger to pry the rear camera connector straight up and out from the motherboard.
Use a heat gun or hair dryer or apply a heated iOpener for about a minute to soften the adhesive around the rear camera.
Carefully pick up the motherboard.
Using your thumbnails, press on the metal bezels to separate the rear camera from the motherboard.
Stop once you feel the rear camera begin to separate from the motherboard. You don't need to press it entirely out yet.
Insert the flat end of a spudger into the gap between the rear camera and the motherboard.
Lift to separate the rear camera from the motherboard.
3 участников успешно повторили данное руководство.
