Введение
If you own the Samsung Galaxy On5 replacing the battery is a breeze. If your phone isn't turning on or the screen is frozen, use these steps to remove the battery.
Запчасти
Никакие детали не требуются.
  1. Locate the side notch that allows you to open the back casing.
    • Locate the side notch that allows you to open the back casing.
  2. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  3. Use a plastic prying tool or your fingernail to pop the back cover off the phone. Use a plastic prying tool or your fingernail to pop the back cover off the phone. Use a plastic prying tool or your fingernail to pop the back cover off the phone.
    • Use a plastic prying tool or your fingernail to pop the back cover off the phone.
  4. Locate the battery notch to remove the battery Be careful not puncture the battery. Lithium-ion batteries are highly flammable when exposed to oxygen. Use a plastic prying tool or your fingernail to remove the battery from its housing and pull it aside.
    • Locate the battery notch to remove the battery
    • Be careful not puncture the battery. Lithium-ion batteries are highly flammable when exposed to oxygen.
    • Use a plastic prying tool or your fingernail to remove the battery from its housing and pull it aside.
Заключение
The Dark Night part 2
Участник с: 19.09.2018
635 Репутация
Автор 5 руководств
Команда
Gateway, Team S1-G5, Luster Fall 2018 Member of Gateway, Team S1-G5, Luster Fall 2018
GCC-LUSTER-F18S1G5
1 член
Автор 5 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 3
За 30 дней: 13
За всё время: 88
